IRS and the SRA - Mustang Evolution
Old 06-28-2014, 02:07 PM   #1
XSlashDashX's Avatar
IRS and the SRA
How long should it take to drop the IRS and put the SRA in?
Old 06-28-2014, 02:17 PM   #2
Mile high JDF's Avatar
Depends on your motivation. It took me a full day to drop my SRA and swap in the IRS. I started at 10ish and finished around 7:30. It should be easier to swap an SRA back in though.
- Silver 2007 Corvette
Current - DHG 2001 Bullitt
Old 06-28-2014, 02:26 PM   #3
Having a shop doing it. How many bolts are on the irs to drop it?
Old 06-28-2014, 02:53 PM   #4
Just have them price out a rear differential R&R. You've got 6 bolts holding the assembly in, various brake line and parking brake bolts, driveshaft bolts, shocks, exhaust, and then a couple connectors.
Old 06-28-2014, 07:11 PM   #5
1lowGT's Avatar
SRA is easy to put in I'm not sure how IRS goes.
Old 06-28-2014, 10:39 PM   #6
Thanks guys. Would I be able to install springs myself?
Old 06-28-2014, 10:49 PM   #7
On the SRA or IRS? Both should be fairly simple. I did my springs with my SRA in my driveway by myself
Old 06-28-2014, 10:55 PM   #8
Depends on how you work and how bad you want it done
snelson1231 is offline   Reply With Quote
Old 06-28-2014, 11:03 PM   #9
IRS and the SRA
Springs on SRA are super easy. I can't say how many times I've had to take them out on my car lol. It takes me longer to jack up he car than to take out the rear springs.
Old 06-28-2014, 11:42 PM   #10
Would I need to bleed the brakes?
Old 06-28-2014, 11:45 PM   #11
Nope. You shouldn't need to disconnect the brake line depending on how you remove the Irs
Old 06-29-2014, 12:25 PM   #12
IRS and the SRA
I should be able to drop the rear with just basic hand tools, correct?
Old 06-29-2014, 12:30 PM   #13
Yes
Old 06-29-2014, 02:21 PM   #14
Sweet, thanks. Also would I need to torque anything down or just hand tighten the bolts when I put the SRA in?
Old 06-29-2014, 02:46 PM   #15
I just tightened everything when I did it, but it's always a good idea to torque everything if you have the chance. A Haynes manual should have all the torque specs or I'm sure you could google it.
Old 06-30-2014, 12:21 AM   #16
Do I need to drop the gas tank?
Old 06-30-2014, 07:13 AM   #17
Nope.
Old 06-30-2014, 01:53 PM   #18
2 jack stands and a jack should be enough? Going to attempt to drop the rear the next 2 days. Hopefully I'll get it done tomorrow. I will only have 3-4 hours to work on it.
Old 06-30-2014, 02:03 PM   #19
The IRS is a heavy *****, just a heads up. Doing it with hand tools I don't know if it can be done in 3-4 hours
Old 06-30-2014, 05:10 PM   #20
Most of the time you spend was on the IRS? Figure I could drop the irs and install the sra the next day.
Old 06-30-2014, 05:53 PM   #21
Yep the IRS was the *****y part. Part of the issue was shoving my head up *** for about half the install
For Trade: SRA for IRS Soccerluvr4 Mustang Parts for Sale and Wanted 0 08-18-2013 12:55 PM
SRA to IRS Build / Install jk_aktion 1996-2004 Mustang GT 3 10-05-2011 05:32 PM
irs to sra swap Black99Snake SVT Mustang 4 08-23-2011 09:41 PM
To IRS or Not to IRS Nel86 1996-2004 Mustang GT 11 06-03-2011 12:31 PM
Whats the difference between IRS and Live rear axel Eos 1979-1995 Mustang GT 7 02-21-2005 04:02 PM
05:17 AM
