What size tires should I buy? - Mustang Evolution
Old 06-30-2014, 12:54 PM   #1
dathird38's Avatar
Red face What size tires should I buy?
Hey Guys,
I have a 2000 Mustang GT Convert and I am in need of new rear tires. My current set up is as follows:
Front wheel - 18x9
Front Tire - 245/40/18
Rear wheel - 18x10
Rear Tire - 275/35/18
I am going to try to not make this complicated but here it goes. I do not like the fact that the side walls on my front tires are bigger then the rear. With that said I would like to find rear tires that are a size wider and the equivalent side wall height as my front tires. Down the road I will be going down to 35s in the front but for now I am just looking for rear tires.
What would be a good tire size for my current setup? Please feel free to post all kinds of options, pictures and even whole staggered setups.
[IMG][/IMG]
dathird38 is offline   Reply With Quote
Old 06-30-2014, 01:46 PM   #2
XSlashDashX's Avatar
265/35/18 fronts
315/35/18 rear.
Old 06-30-2014, 02:11 PM   #3
Mile high JDF's Avatar
Originally Posted by dathird38 View Post
Hey Guys,
Front wheel - 18x9
Rear wheel - 18x10
[IMG][/IMG]
If you want matching side walls then step up to a 275/40R18
- Silver 2007 Corvette
Current - DHG 2001 Bullitt
Old 06-30-2014, 02:17 PM   #4
Loc: Austin,TX
A 315 on your car would be a waste of money. Unless you are putting down some serious power you don't need that. Trim the sidewall fat on the fronts or beef up the rear sidewall. A 275 in the rear is a great tire for what you have.
Old 06-30-2014, 03:51 PM   #5
dathird38's Avatar
I agree, 315 is a size to big and more expensive. I was thinking at most 295. I want to stay between 285 and 295 depending on which aspect ratio will give me a bigger side wall in for the rear.
Sent from my HTC6525LVW using Mustang Evolution mobile app
Old 06-30-2014, 04:25 PM   #6
What tires do you currently have because 245/40 18 275/35/18 should look proper together
TurboCobra is offline   Reply With Quote
Old 06-30-2014, 09:28 PM   #7
GHO5T5NIPER's Avatar
Go 315's and don't look backClick image for larger version
Name:	ImageUploadedByMustang Evolution1404185302.976952.jpg
315 on left 245 on right
GHO5T5NIPER is offline   Reply With Quote
Old 07-02-2014, 06:27 AM   #8
Something is wonky with your tires because a 245/40/18 and a 275/35/18 have the exact same diameter and therefore will have the same sidewalls. You sure those sizes are what you have?
Go on tirerack and just get a staggered setup that has a matching overall tire diameter or really close, like within .1 or .2". If the diameters are the same and the rim opening is the same then the sidewall height will be the same too.
edit: Also the stock 25.7" tire diameter for a 94-04 car looks like a damn roller skate wheel. I suggest going up a sidewall size on the front and rear or even two out back. I run a 235/45/18 up front on a 18x8 and a 275/40/18 out back on a 18x10. As you can see I have room to go up a full extra inch probably because that's only = .5" tighter to the wheel well.
There is also no reason to go bigger than a 275 or 285 on a 10" wide rim. My 275s bulge out just very slightly which is optimal.
what size tires should i get? cj92 Mustang Wheels & Tires 13 12-18-2013 11:59 AM
Tire size and rim size 96gt Lios 1996-2004 Mustang GT 9 04-22-2012 10:33 PM
Which tires should I buy for my Mustang? Torran Mustang Wheels & Tires 1 12-13-2011 02:30 AM
Wheel size & tire size help needed for newbie rayramos Mustang Wheels & Tires 14 09-21-2009 11:45 AM
03:28 PM
