96 gt hesitation under load - Mustang Evolution
Old 06-30-2014, 08:02 PM   #1
Region: Utah
96 gt hesitates under load. First noticed it 5th gear now it does it in 4th also. It's worse as the daytime temperature goes up. It was throwing o2 sensor codes and insufficient egr flow codes. Replaced the egr with a used thoroughly cleaned egr and it didn't help. Found a blown gasket on passenger side between exhaust manifold and exhaust pipe. Replaced that. Seemed to run great for a few days. Now it's worse than ever. Pulled the codes , same codes are back. It has a cai and a Mac offroad h-pipe with Pypes exhaust.
97Frankenstang is offline   Reply With Quote
Old 07-01-2014, 01:53 PM   #2
Did you try replacing the o2 sensors. Bad o2s can mess with your fuel trims and that can cause hesitation under load
Cant shift under high load. Combatman 2005-2010 V6 Mustang 11 09-06-2013 06:36 AM
04 Mach 1 stalling and occasional studder under load kevinfm91 1996-2004 Mustang GT 5 05-15-2013 09:23 AM
Shutters under load Rockpanama 1996-2004 Mustang GT 6 11-11-2012 12:42 PM
Engine popping under load Travis B 1979-1995 Mustang GT 6 07-02-2012 06:30 AM
Ticking under load MustangGT02 1996-2004 Mustang GT 13 01-18-2012 02:40 PM
01:23 PM
