Tubro or supercharged - Mustang Evolution
Old 07-02-2014, 03:07 PM   #1
ryank64's Avatar
What should I go with and do I have to upgrade my engine before I put any in
Sent from my Nexus 4 using Mustang Evolution mobile app
ryank64 is offline   Reply With Quote
Old 07-02-2014, 03:59 PM   #2
Riverdale's Avatar
well the turbo is gonna kick in after a certain rpm (turbo lag).. the supercharger is gonna always be there from low rpms to high rpms.. so from acceleration the supercharger is better but as the rpms start the rise the turbo charger has the advantage i believe.. but beef up the suspension so you can put the power to the wheels and build up the bottom end if u plan to run a high amount of boost
Riverdale is offline   Reply With Quote
Old 07-02-2014, 11:14 PM   #3
Right about the suspension, wrong about the blowers. Superchargers depend on what type you pick. A positive displacement blower will bring on the power early but won't pull as hard up top as a centrifugal or a turbo will. A centrifugal supercharger is basically a belt driven turbo and will come on in the higher RPMs and keep on pulling. Superchargers take power to make power though, you have to deal with belt slip but they are simple. A properly selected turbo setup, on the other hand, will come into boost pretty early, not run out of steam up top and uses very little power to make its power seeing as it is just wasted exhaust gas. Also no belt slip. They are a more complicated install though but with so many kits out nowadays its not nearly as bad as it once was.
IMHO, PD blower for a manual street car, centrifugal blower for a stick shift weekend warrior or 1/4 car and a turbo setup for any automatic. Autos are turbos are like peas and carrots.
Old 07-02-2014, 11:18 PM   #4
Riverdale's Avatar
do me a favor scotty, just for me, change your name to scottydoesknow
Old 07-02-2014, 11:22 PM   #5
ryank64's Avatar
Can I run a stock engine or will it harm it
Old 07-02-2014, 11:25 PM   #6
4.6 internals are good to around 400whp, after that is when you want to look into a forged rotating assembly.
Old 07-02-2014, 11:27 PM   #7
ryank64's Avatar
OK well I got a CAI and a thorttle body and and exchuast and a tune what would I be around would u say
Old 07-03-2014, 10:53 AM   #8
Mile high JDF's Avatar
240whp if you're lucky
- Silver 2007 Corvette
Current - DHG 2001 Bullitt
Old 07-03-2014, 12:06 PM   #9
ryank64's Avatar
So a supercharger wouldn't hurt
Old 07-03-2014, 12:27 PM   #10
If you have a good tune it won't hurt your engine. However, if you are still on the stock suspension you'll never see the benefits of the added power because you'll be unable to effectively put the power to the ground. At least a basic lowering/control arms and wheel/tire setup is required to utilize even bolt on power.
Old 07-03-2014, 12:29 PM   #11
ryank64's Avatar
I got a bama tune I'm on the proformance one at all times
Old 07-03-2014, 12:33 PM   #12
You'll need a new tune if you get a supercharger. Bama doesn't tune for superchargers.
Old 07-03-2014, 12:45 PM   #13
ryank64's Avatar
O ok
Old 07-03-2014, 12:55 PM   #14
Yeah you also can't just run any old tune on a supercharger. You need to take it to a tuner and have the A/F dialed in and get it really spot on or you'll blow something up. Its not really all that hard, I mean you install the supercharger and then trailer/flatbed the car to the tuner who will load a basic tune and then dial it in.
If you don't buy the full kit you'll also need to upgrade the fuel system.
Old 07-03-2014, 01:45 PM   #15
ryank64's Avatar
O OK thanks a lot man your been a big help
Twin tubro questions? RedSleeper General Mustang Discussion 16 07-16-2013 09:35 PM
Did ford make a 1988 mustang tubro model Maichail General Mustang Discussion 5 03-27-2010 07:18 PM
94-98 V6's that want to get supercharged, and 99+'s later tire Pre-2005 V6 Mustang 11 07-27-2004 07:04 PM
Going supercharged? will it happen? Looking Good! MaestroSC Pre-2005 V6 Mustang 21 12-13-2003 10:11 AM
supercharged v6? stangracer Pre-2005 V6 Mustang 16 11-03-2003 08:45 AM
06:22 AM
