4.6 Turbo build - Mustang Evolution
Old 07-03-2014, 07:52 AM   #1
ProjectTurboV6's Avatar
4.6 Turbo build
1996 4.6 4v
Block bore 3.700
Forged scat crank 3.750
Diamond 11cc pistons, 9.5:1
Carrillo rods
B heads stage 3 port&polish
Custom MMR manifold...
Aspirations of 650+ rwhp. I've assembled the above parts but don't know what kinda cams to go with and how big of a turbo. I was thinking a 76mm..or should I go bigger??
ProjectTurboV6 is offline   Reply With Quote
Old 07-03-2014, 07:58 AM   #2
On a built motor I would go in the 80s for the turbo..... And that's a pretty good bore size.
Old 07-03-2014, 12:41 PM   #3
Looks good except I would go with C heads over the Bs. Yeah the B heads can make good power but the C head will do better throughout. If you are dead set on staying with the B heads I wouldn't port them, they don't need it. Valve job, IMRC delete and run them as is. You can also make 650whp with stage 2 ported PI heads if you were ever thinking of staying 2V. TFS head obviously will too.
A 76mm should get you to your power goal and stock 96-98 Cobra cams will get you to 650 no problem.
Before you start have you ever thought of a Coyote swap over a modular 4V build? Price them both out and I'm willing to bet it would be cheaper to do the Coyote.
Old 07-04-2014, 02:23 AM   #4
I already have 65% of what I need for this 4v build, but I did price it out and through the hook ups I had this was far cheaper. I'm going with the B heads but I'm going to get a 4-5 angle valve job on them and that's about it I guess. I should've put into account that it's already made for forced induction haha
3.8 Twin turbo build! dwood63 Pre-2005 V6 Mustang 31 12-21-2016 03:57 PM
want to "build" my motor for a turbo frank07stanggt 2005-2010 Mustang GT 1 01-27-2012 01:39 PM
twin turbo build. 35anngt 1996-2004 Mustang GT 10 04-27-2011 10:44 PM
My turbo build up! VCS_SSSTANG Pre-2005 V6 Mustang 19 02-27-2009 09:47 PM
my turbo build up Kyle Pre-2005 V6 Mustang 71 08-01-2008 11:07 PM
06:37 AM
