Transmission rattle - Mustang Evolution
Old 07-05-2014, 04:26 PM   #1
ward.r's Avatar
Transmission rattle
I have the t-45 transmission and recently it has started grinding on occassion in 4th and 5th gear and only like once in second. Then just a couple days ago i have a rattle but its only in 4th that i hear it. You can tell its metal. It sound like something bouncing around inside it but once i hit 5th or 3rd it will disappear. It dont always do it but when it does its only 4th. What could it be? Clutch? Syncros? Gears or shifting forks??
Sent from my SAMSUNG-SGH-I537 using Mustang Evolution mobile app
ward.r is offline   Reply With Quote
Old 07-06-2014, 10:52 AM   #2
Basshunter's Avatar
I also have t45 and it made that noise in 5th then I found out the problem was it was leaking and not getting enough fluid to those parts . Does the noise sound like marbles bouncing around if so that was happening to me. Check your leaks and make sure your transmission is full of fluid
2003 full Bolt on GT
Basshunter is offline   Reply With Quote
Old 09-02-2014, 03:42 AM   #3
ward.r's Avatar
Well I checked and did see what looked like leaks but when I checked the fluid it was full. The rattle seems to b gone now jus grinds 5th if im goin to fast and shutters in reverse
Sent from my C6725 using Mustang Evolution mobile app
Old 09-02-2014, 10:05 AM   #4
Semerollin's Avatar
Change your fluid.
Semerollin is offline   Reply With Quote
Old 09-30-2014, 02:18 AM   #5
ward.r's Avatar
Ok update to the transmission issues. I changed the fluid and even after so it kept on doing the same thing and then gained a shutter when using reverse like it didnt wanna move. Then over night it seemed there was nothing wrong at all no grinds nothing. Then 5th was the only one that grinds then now tonight it works just fine sometimes then other times its like 5th is blocked and dont exsist. Not sure what the deal is with it. Any ideas??
Sent from my SPH-L300 using Mustang Evolution mobile app
Transmission leak and rattle...Help! Depack21 2005-2010 Mustang GT 0 01-31-2014 11:08 AM
Manual transmission rattle when applying throttle at mid rpm CUBuffalo 2011-2014 V6 Mustang 18 01-28-2014 08:41 AM
Can you change a manual transmission to an automatic transmission 2007 mustang? Ekon General Mustang Discussion 3 12-18-2011 03:09 AM
Dash Rattle?? Tranny Rattle?? ricklmesa Pre-2005 V6 Mustang 0 03-08-2006 07:19 PM
Transmission Question: 1997 V6 Automatic Transmission ?? svtmustang88 Pre-2005 V6 Mustang 4 12-09-2003 04:49 PM
05:01 PM
