Car stalls when I stop really fast - Mustang Evolution
Old 07-06-2014, 10:40 PM   #1
rollo1987's Avatar
So I changed the IAC on my mustang. 2003 GT automatic. Now when I rev fast the car won't stall. But if I'm driving at 50 mph and stop really fast it will stall before I get to a full stop. Going to try the TPS sensor next. Any suggestions
rollo1987 is offline   Reply With Quote
Old 07-07-2014, 01:06 AM   #2
If you got that IAC from AutoZone, or the like there is a good possibility of it being defective right out of the box.
Id use an IAC that is manufactured by Hitachi or Motorcraft only.
Also, when you replace the IAC, you need to disconnect the battery for about 15 minutes so that it will clear the computer's memory and it can then relearn the correct idle trim with the new IAC.
Old 07-07-2014, 01:10 AM   #3
rollo1987's Avatar
I got the part from rock auto. I didn't know about disconnecting battery. I will try that before getting a TPS. The car is running better than before. So that's good.
Old 07-07-2014, 04:28 PM   #4
rollo1987's Avatar
So I tried to disconnect battery. Didn't work. I just got the TPS so let's pray it works.
Old 07-07-2014, 09:36 PM   #5
So how did it go?
You need to do the battery disconnect when changing the TPS, and all of the other sensors as well.
Old 07-09-2014, 02:24 PM   #6
rollo1987's Avatar
So te TPS broke while
Installing both the new and old. Is there a special way to instal it.
Old 07-09-2014, 02:36 PM   #7
You need to get the tabs that are inside of the TPS to slide over the shaft on the throttle body. You may need to rotate the TPS backwards, or counter-clockwise, initially so that the tabs slide over the flat spots on the throttle shaft. Once it's all of the way in, the TPS will be right up against the throttle body and THEN you can put the screws in and tighten it down.
Old 07-09-2014, 02:41 PM   #8
rollo1987's Avatar
I had it that way. Did exactly that. When I was tightening screws heard a snap in the TPS
Old 07-09-2014, 02:46 PM   #9
Well it wasn't all of the way on the shaft. When it's on right, it will be tight against the TB and can't break the way you just described.
DO NOT TIGHTEN IT IF IT ISN'T!
Old 07-09-2014, 02:59 PM   #10
And I got the rotation backwards...
You'll probably have to rotate the TPS clockwise, or towards the back of the car to get it on the shaft.
You'll feel it go on. You can also move the throttle a little while you are putting it on. It will be tight up against the TB with no gap. You shouldn't have to tighten the screws to close the gap.
Old 07-09-2014, 03:55 PM   #11
Like the others said, the key way on the TPS wasn't lined up with the shaft. You'll probably have to rotate the TPS (before you put the bolts in) about 1/8 turn to get it to drop in. Then maintain pressure with your hand on the TPS pushing it towards the throttle body so the shaft doesn't slip out and turn the TPS till the bolt holes line up. Insert the bolts and tighten lightly. Once you are sure it's seated correctly, snug up the bolts.
The other thing is, they might have sold you the wrong TPS.
Some cars use a TPS that rotates clockwise and others counter clockwise.
I forget what Mustang is but they both look the same. The only difference is which way the wiper inside the TPS is supposed to turn.
Just something to check.
vert03 is offline   Reply With Quote
Old 07-09-2014, 04:08 PM   #12
Yes.^
Take a look at the inside of the TPS where it slides onto the throttle shaft, and look at the throttle shaft itself. That will give you a good idea of how it fits and how you'll have to rotate it.
Old 07-09-2014, 06:54 PM   #13
rollo1987's Avatar
Yea I'm in az right now. Have to get a new one then when I get back try again
Old 07-17-2014, 03:37 PM   #14
rollo1987's Avatar
I hooked it up. It works now. I just need I disconnect the battery and clear the comp
HELP! Car stalls with new Bama tunes GT Gone 2005-2010 Mustang GT 2 01-08-2013 07:58 AM
car stalls when stopping 86 stang gt 1979-1995 Mustang GT 2 05-20-2011 10:55 AM
Car stalls in drive SeadudeRXP Pre-2005 V6 Mustang 9 12-29-2005 08:40 AM
Ah!ah! Stop! Stop It!!! chips The Bar 21 09-24-2004 05:09 PM
Code reading? and Car that idle Lobes and stalls stick0014 Pre-2005 V6 Mustang 4 09-03-2004 08:33 PM
10:42 PM
