kphunter49 1998 mustang gt auto - Mustang Evolution
Old 07-08-2014, 01:45 PM   #1
I have white smoke drivers side exhaust and fuel coming out same pipe car runs very rough before I blew the doors off a Audi A6 the car ran fine I know I had to replace 1 or all 4 02 sensors but now white smoke and fuel left exhaust did I blow my head gasket on the left side ? answers please !
kphunter49 is offline   Reply With Quote
Old 07-08-2014, 01:50 PM   #2
V6 stang's Avatar
How are your coolant levels? It doesn't sound good.
2012 Mustang GT Convertible
Roush Exhaust
2003 Mustang GT (Sold)
Old 07-08-2014, 01:54 PM   #3
coolant fine no knocks or ticks rough idle
Old 07-08-2014, 03:43 PM   #4
XSlashDashX's Avatar
Check your oil. If it's milky you blew a head gasket.
Old 07-08-2014, 05:21 PM   #5
Yeah. See if there's coolant in the oil.
It also could have blown the gasket right in between two cylinders.
The next thing to do would be to remove the spark plugs on the drivers side bank and have a look to see which cylinder, or cylinders, aren't firing.
Keep the plugs in order so you know which cylinder that they came from.
Depending on the year, this could just be a bad coil or spark plug wire.
Hopefully...
Old 07-09-2014, 04:43 PM   #6
No coolant in oil and what two gasket between the cylinders and could bad 02 sensors cause this
Old 07-09-2014, 05:18 PM   #7
That's a good sign!
If the head gasket blows out directly between two cylinders, it is possible for there to be NO coolant leak, but, those to cylinders will have little or no compression and, therefore, will not fire
Let's hope that isn't the case here...
I don't know if it could be the 02 sensors or not. Generally, at this stage, I would expect that they would be throwing a code, which you should scan for, anyway, even if the Check Engine Light is not lit up. There may be a pending code nonetheless.
You only need to replace the two upstream 02 sensors if you plan on replacing them, by the way.
This sounds like a cylinder, or cylinders, not firing to me.
You just need to find out why.
If you have a way to scan for codes, do that first. If not, do what I said in the earlier post so that you can figure out which cylinder is the problem.
1998 mustang
Kp Hunter 49 1998 Mustang GT Auto/Stock kphunter49 1996-2004 Mustang GT 3 07-01-2014 04:05 PM
1998 v6 auto 1998v6stang Pre-2005 V6 Mustang 1 10-02-2013 11:32 PM
Would a 1998 mustang gt engine fit in a 1998 v6 engine bay? imported_Buster 1996-2004 Mustang GT 1 12-14-2011 06:19 PM
Mustang GT - Previous Mustang :: 1998 Ford Mustang GT Tib Member Garages 0 06-15-2011 12:01 PM
Auto vs Auto ERICK Pre-2005 V6 Mustang 4 05-12-2003 11:03 PM
08:21 PM
