three keys - Mustang Evolution
Old 07-09-2014, 08:06 PM   #1
three keys
my car came with 3 keys.
a Big one with a squared end for the ignition
a longer skinny one for the trunk
and then another Bigger key with more of an oval end.|
It does not open the door or trunk but it does fit in the ignition and will crank the car but not start it?. The cut is different then my ignition key and I have always just assumed it opened the trunk and never used it haha big useless ford key on my keychain for years
---------- Post added at 08:06 PM ---------- Previous post was at 08:05 PM ----------
does your car have the same?
---------- Post added at 08:06 PM ---------- Previous post was at 08:06 PM ----------
TurboCobra is offline   Reply With Quote
Old 07-09-2014, 08:54 PM   #2
Mine just has one key that does everything.
Old 07-09-2014, 09:16 PM   #3
V6 stang's Avatar
Maybe the car has been crashed and they got a trunk from a junkyard. Your one key that's cranks your car should be good for everything. Something's wrong if it isn't. I have 2 keys (with the chip) along with a key fob. Your key that will go In the ignition but won't crank it has most likely been made by someone like Walmart. It can be used to enter the vehicle, but lacks the chip which fires the engine up.
Yes I edit my posts a lot, auto correct likes to sabotage me!
2012 Mustang GT Convertible
Roush Exhaust
2003 Mustang GT (Sold)
Old 07-10-2014, 12:00 AM   #4
The key that goes in the ignition and will crank but not start the car is a ford key looks just like my main one but is oval not square on the end. Strange.
My Ignition key does not open my door or trunk. No accidents that I know of, Had this car for about 7 years now and always had the three keys on my keychain yup never used that key, decided to and it only cranks the car
Old 07-10-2014, 08:51 AM   #5
It should only be one key like this:
And that is to open everything
Other cars like my camaro for example use two keys like these:
One for the door/locks and one only for the ignition
I personally think whoever came up with the 2 key design is an ******* lol
MyLilPony is offline   Reply With Quote
Old 07-10-2014, 08:52 AM   #6
V6 stang's Avatar
That's very odd. The ford one doesn't have a chip and that's why the car won't crank with it. Your main one not unlocking the trunk or door seems suspicious, and abnormal. My 99 had 1 key... All the fords I've had 98-03 have had 1-2 main keys that did everything.
Roush Exhaust
Old 07-10-2014, 09:28 AM   #7
The keys on our cars don't have external chips like Chevys. It's in the actual key, which is why it's a bit bigger. The one key should do everything.
If the key that starts your car doesn't open your door then it's possible your ignition assembly got replaced.
Old 07-10-2014, 12:50 PM   #8
Someone before you probably jacked with the tumblers or whatever. The one big key is the only one you got from the dealer for a SN95 car with PATS. Well, you got two.
Old 07-10-2014, 06:39 PM   #9
Two big keys both fit the ignition and crank it but only one starts it.
Weird that they are both ford and different cuts but both fit and crank it.
Old 07-11-2014, 05:34 AM   #10
That is odd but not unheard of. Only the square one starts it because that is a PATS key, the other one isn't.
Old 07-11-2014, 09:27 AM   #11
Davesorl04gt's Avatar
My 04 came wit two keys, His and Hers. I bought two more for spares, had them cut, the cutter messed one up so it doesn't work nothing. They came with instructions on how to program them but then I found out that you need two factory keys to program them yourself. I had only one factory and one that wasn't factory. The spare thats not programed only turns the engine but wont start it. Yes they do have chips in them.
Davesorl04gt is offline   Reply With Quote
Old 07-11-2014, 01:29 PM   #12
well after 7 years its finally off my keychain
Old 07-11-2014, 01:57 PM   #13
Attachment 161138
Attachment 161139
Haha
It was probably someone back in the 1950's or earlier. All of the American cars, that I can think of, had a separate key for the door locks and the ignition until around the late 90's. It probably carried over from the days when door locks, and keyed ignitions, were factory "options", early on.
I believe that it was the Japanese who started the one key trend.
Locked keys Gigerdavid General Mustang Discussion 26 01-04-2012 12:40 PM
dad finally gave up the keys jcford New Member Introductions & Greetings 37 11-19-2011 10:36 AM
Car Keys woodly1069 1996-2004 Mustang GT 3 12-06-2007 04:57 PM
Bump keys... traditional door locks are useless if this catches on SilentNoise The Bar 12 08-29-2006 01:12 PM
spare keys 1997grnstang Pre-2005 V6 Mustang 11 06-24-2004 07:00 AM
07:23 AM
