Kenne bell non intercooled kit questions - Mustang Evolution
Old 07-10-2014, 02:52 PM   #1
Ahmed ali khan's Avatar
Hello everyone
I need some help on my car
I have a 2004 mustang GT
I use it as daily day
I have all the boltons in the car
And i have installed stage 2 comp cams 268H i think which work with stock tune as well
Now i want to supercharge my car
I dont want to change the block
So is 6psi kenne bell non intercooled kit with cams good for me?
how much power it will make any idea
And i will be on 6psi only
Will non intercooled kit have heat issues?
I am going with this kit because i think boltons and cams on intercooled kit may effect my block
So what you guys suggest
Non intercooled 6psi kit
Or intercooled with 8psi
I want to use car as daily day and wana have some fun thats it
I have an 05 GT which i will modify for track use only
Ahmed ali khan is offline   Reply With Quote
Old 07-10-2014, 04:14 PM   #2
What about intercooled at 6psi?
MyLilPony is offline   Reply With Quote
Old 07-10-2014, 04:26 PM   #3
I dont think 6psi intercooled will work
Because in there site it says 8-14psi intercooled kits are available
Old 07-10-2014, 04:59 PM   #4
Don't get non intercooled. I'm not sure why you think intercooling is going to hurt your motor but that is not correct. You also need to list what else is done to the car. "All the bolt ons" isn't much to go on really. You are also leaving a good chunk of power on the table without tuning for the Comp cams you have. Maybe get a dyno tune and see where you are at because a tuned 2v with the Comp cams vs what you are at now is going to pick up a solid 30-50rwhp.
Old 07-10-2014, 05:11 PM   #5
It is tunned with SCT tunner custome tunned
The car is at 310rwhp
If i will go with kenne bell intercooled
The car will be around 450rwhp
Which is alot for stock bottom end
I just need to conform 8psi cammed kenne bell with kenne bell tune which is safe most people say
Will it be safe with cams?
I just need to conform this from all the experts and experienced people here in this forum which you guys are
If its safe i will go with 8psi kit
Old 07-10-2014, 05:23 PM   #6
You don't have to run 8 psi, you can run whatever you want, just get the right pullies. And that 450 number is just a guesstimate from KB, research around on here and other mustang forums as to what ppl are making with the KB kit.
Old 07-10-2014, 06:30 PM   #7
saleenfan04's Avatar
With ur cams and 9psi on 2.1 KB u be running around 430hp. Kenne bell doesn't sell none cooler kit no more. Just go with 2.1kb and u be more then happy right now on my stock motor noting else just 2.1 KB supercharger m running 9psi with 391hp but with ur cam setup it's easy over 430hp hope this help
Don't Judge Me
saleenfan04 is offline   Reply With Quote
Old 07-12-2014, 06:16 AM   #8
Can i run 6 or 7psi on intercooled kit
If yes that will be great
Old 07-12-2014, 06:19 PM   #9
Yes u can
built not bought
Stroker kit or Kenne Bell? Graham1992 2005-2010 Mustang GT 7 09-15-2012 02:22 AM
questions about the kenne bell ArmyScout 1996-2004 Mustang GT 9 04-10-2011 06:16 PM
Kenne Bell GT500 Edition bluemustang General Car Discussion 40 03-10-2007 02:32 PM
I am the first to post a Kenne Bell blower thread, lol. 427windsorman 1979-1995 Mustang GT 4 02-27-2004 02:35 PM
03:22 PM
