Driveshaft removal help - Mustang Evolution
Old 07-10-2014, 04:33 PM   #1
XSlashDashX's Avatar
How do you remove the bolts to the driveshaft? Trying to drop the irs and stuck at the driveshaft. Is it a 12mm? Sockets won't fit.
Old 07-10-2014, 05:01 PM   #2
12mm 12 point socket. It has to be 12 point. You're likely going to need a breaker bar.
Old 07-10-2014, 06:06 PM   #3
Thanks, got it off. Had to use jack to get it off. How to I get the rear shocks off? From the trunk?
Old 07-10-2014, 06:23 PM   #4
The_Chech's Avatar
Yeah to get the shocks off you have to move the inner plastic carpet things from the sides. only a few plastic screws and then they move out of the way and you can get to the top of the shock mounts
The_Chech is offline   Reply With Quote
Old 07-10-2014, 06:29 PM   #5
The_Chech's Avatar
Name:	ImageUploadedByMustang Evolution1405038392.052536.jpg
ID:	161175Click image for larger version
Name:	ImageUploadedByMustang Evolution1405038403.350668.jpg
ID:	161176Click image for larger version
Name:	ImageUploadedByMustang Evolution1405038418.600660.jpg
Should only be a few screws and once you get the plastic pieces out the way you can find the nut that holds on the shock on
Oxford White Roush Stage 1 SN# 6925--SOLD but never forgotten!
Kona Blue GT premium - Slammed on BC's and BMR's full rear suspension
Old 07-10-2014, 06:39 PM   #6
Do I need to remove brake lines?
Old 07-10-2014, 07:03 PM   #7
When I try taking the bolts from the top the shock keeps spinning?
Old 07-10-2014, 07:21 PM   #8
The_Chech's Avatar
have to use two wrenches. Cant remeber the size but its a really small for the one that goes on the stud of the shock and a larger one for the nut that holds the stud of the shock. Its squared off on the stud so you can fit one on there.
Old 07-10-2014, 10:34 PM   #9
Thanks, got it off! IRS is dropped. But the abs is still connected? How do I remove the abs?
Old 07-10-2014, 11:41 PM   #10
Mile high JDF's Avatar
The sensors? Remove the lower half of the rear seat and you should see the plugs right there
- Silver 2007 Corvette
Current - DHG 2001 Bullitt
Old 07-11-2014, 12:19 AM   #11
Thanks! Should finish it by tomorrow. IRS is dropped just cannot move it until I remove the ABS Sensor. One last question. Removing the front springs, I just drop the shock and it will pop out? Already took off the sway bar link?
Old 07-11-2014, 06:33 AM   #12
Yeah just remove the lower shock bolts and then it comes out. Be careful of the front ABS sensors and brake lines though.
Old 07-11-2014, 07:12 AM   #13
Thanks, and do I need to take the brake lines/caliper off with the IRS or will it fit the sra?
Old 07-11-2014, 07:23 AM   #14
You may have to modify the lines a bit but the calipers are the same. The brackets for the calipers will be different though but if you are putting in the IRS the brackets should be on it.
Old 07-11-2014, 07:31 AM   #15
It will fit the SRA just fine. Depending on how you want to go about it, I just removed the top control arm bolt of the IRS and slipped the
brake calipers and line through there.
I thought you only had to do that for the SN95, not a New Edge. Mine went in with no problems
Old 07-15-2014, 03:15 PM   #16
Bolting up the sra tomorrow. Is it just the control arms, shocks that bolts to the frame?
Old 07-15-2014, 07:02 PM   #17
Yes.
Old 07-16-2014, 11:26 PM   #18
Well the bolts he gave me were to small. Wouldn't work. What bolts do I need? I have the sra in place and ready for bolts.
Old 07-17-2014, 05:42 AM   #19
Jump on Official Ford Parts Site | Buy Motorcraft & OEM Ford Parts Online | FordParts.com and start looking at diagrams. Any nut or bolt you need should show up and when you click on the list that is to the right of the diagram it should even give the dimensions. That's how I found out I need a replacement M12x1.75 nut for my rear left shock, just as an example.
Old 07-17-2014, 08:44 PM   #20
So I went to the dealership and they said they discontinue them. Check Autozone and hardware stores nearby and none of them have it. So I've been looking online.
99-04 Ford Mustang Grade 8 Rear Bolt Kit
JEGS Mustang Control Arm Bolts - Free Shipping on All Orders @ JEGS
I need to get the bolts for the Upper and Lower Control arms.
Upgrade Your Weak Stock Driveshaft with The Driveshaft Shop at AmericanMuscle AMWill AmericanMuscle 1 03-16-2014 02:18 PM
help driveshaft rubbing!!! Clean98 Gt 1996-2004 Mustang GT 2 12-17-2013 10:53 PM
Power Steering Pump Removal Help Justin 1979-1995 Mustang GT 7 03-12-2007 07:24 PM
Help! Removal Of Wing 2007 V6 project_v6 Pre-2005 V6 Mustang 6 12-22-2006 10:54 PM
Benefits of an aluminum driveshaft... i need some help Zim Pre-2005 V6 Mustang 26 04-05-2004 08:49 AM
08:46 AM
