Engine help! - Mustang Evolution
Old 07-13-2014, 11:09 PM   #1
to_oaxaca's Avatar
Region: Nevada
Engine help!
So today after work I started my car up and it turned on automatically, adter i drove for about 2 minutes, it just shut off. I tried turning it on but didnt start. Once in a while it would turn on, stay idle for about 30 seconds but shook very terribly then it shut down. Also if I stepped on the throttle, it would turn off immediatly. Any ideas what it could be? Its my daily so I need help ASAP! Thanks, in advance!
to_oaxaca is offline   Reply With Quote
Old 07-13-2014, 11:31 PM   #2
Mfore33's Avatar
Sounds like fuel pump. Or other fuel related issue. You can have a friend turn the car to run while you lay under the tank and listen for the pump to prime. My cars pump died like that. Best of luck.
Old 07-14-2014, 12:09 AM   #3
Sounds fuel related to me also.
If you have access to a fuel pressure test gauge, it will make it very easy to tell if it's the fuel pump failing.
Old 07-14-2014, 03:19 AM   #4
to_oaxaca's Avatar
Region: Nevada
Even tho I recently changed the fuel pump? That was about 2 or 3 months ago
Old 07-14-2014, 03:21 AM   #5
to_oaxaca's Avatar
Region: Nevada
One of my neighbors told me it might be one of the fuel injectors failing; he also told me what you have said, so hopefully might get it checked in tuesday :'(
Old 07-14-2014, 07:29 AM   #6
Kbasham5's Avatar
Check fuel filter also.
Kbasham5 is offline   Reply With Quote
Old 07-14-2014, 08:56 AM   #7
Site Sponsor
Like it's being said I would check on the fuel side as well! Any mods on the car? Anything installed or replaced in the past few days?
Alex
Toll Free: 1-866-363-4591
Free Same-Day Shipping!
Engine died at low speed. Could not start engine in hot weather Ucla1998 Pre-2005 V6 Mustang 5 08-09-2011 02:15 AM
check engine light code help p0102 HELP! slow98gt 1996-2004 Mustang GT 1 05-21-2009 01:52 PM
Engine noise from COLD engine 03GreyMach1 1996-2004 Mustang GT 10 03-14-2008 07:40 PM
engine swap 1989 to 1992 4 cyl engine dannyc1992 General Mustang Discussion 0 02-08-2008 01:59 PM
Engine Swap/ Engine Shakes too_cool_mitch Pre-2005 V6 Mustang 2 02-28-2006 02:01 PM
03:19 PM
