Squeaking - Mustang Evolution
Old 07-14-2014, 08:30 PM   #1
cobrah's Avatar
Squeaking
Hi I have a 96 gt, 63k miles and a manual transmission. Every time I start the car cold, it makes a sqeuking noise, even when I run through the gears. It goes away after about 10-15 miles, however, the belt and tensioner are fine and had the yolk greased up and had the rear pinion replaced. Any ideas that could be causing the noise?
cobrah is offline   Reply With Quote
Old 07-14-2014, 08:43 PM   #2
Check all of your pulleys. I had a squeak and turned out to be the water pump pulley and I just ended up replacing the whole water pump.
MyLilPony is offline   Reply With Quote
Old 07-14-2014, 09:26 PM   #3
cobrah's Avatar
How much did that run ya?
Old 07-14-2014, 09:38 PM   #4
Not that much like $50 if that
bad squeaking noise on 3.8 01' mustang jumpman1203 Pre-2005 V6 Mustang 9 07-27-2015 01:03 AM
To get rid of squeaking... crazeflier07 Pre-2005 V6 Mustang 0 08-08-2007 08:14 PM
Squeaking Noise joekool9 Pre-2005 V6 Mustang 3 08-03-2004 09:38 AM
Car Squeaking Over Bumps/Hills/Rolling Roads Shahrum Pre-2005 V6 Mustang 12 03-03-2004 08:47 PM
can't stop doors from squeaking stangracer Mustang Audio & Video 11 11-11-2003 11:08 AM
05:34 AM
