Water - Mustang Evolution
Old 07-16-2014, 12:47 PM   #1
Water
car is dribbling underneath as if the AC is on but its not. Straight water it appears to be and not coolant? dripped to much to be just moisture. I cant seem to see where its coming from but that black canister in the top left corner appears to be wet.
TurboCobra is offline   Reply With Quote
Old 07-16-2014, 12:53 PM   #2
bucko's Avatar
That black canister you are describing is the receiver/dryer. Is it this:
It gets very cold when the A/C is on...are you sure the A/C is not operating when you say its off? Are you using the windshield defrost mode? If so, this operates the A/C compressor.
Old 07-16-2014, 01:03 PM   #3
Yes that is what I am speaking of. The top of it where those tubes connect seems to be a bit wet. No AC is off and setting is turned to off even moved the control to heat and still dripping. Its definitely water, no smell or colour and I use coolant in my car, so what could cause that much water?
Old 07-16-2014, 01:20 PM   #4
is it possible that canister is leaking fluid some how?
Old 07-16-2014, 10:23 PM   #5
michaelsneal's Avatar
that canister only holds the R134A refrigerant . if it is leaking it would not be water.
check to see if all drain holes are clear and also the condenser tray drain is also not clogged.
there should be drain holes in the wiper motor/arm area which is under the plastic cover. use a flash light to see if its full of water. this does happen due to leaves and dirt buildup .
michaelsneal is offline   Reply With Quote
Old 07-17-2014, 11:53 AM   #6
JHghers's Avatar
Ac is off, but is your defrost running? At times you ac compressor will kick in when defrost is running.
JHghers is offline   Reply With Quote
Old 07-17-2014, 12:07 PM   #7
weird, I have never noticed this before ever this seems to be excessive. not sure why the canister is all wet everything looks to be connected
electric water pump? widowvirgin Pre-2005 V6 Mustang 15 07-01-2004 04:30 PM
Water in Exhuast? And gear shift? Ibanezplayer272 Pre-2005 V6 Mustang 16 06-04-2004 11:22 AM
Pics of the car with fresh coat of water less car wash SpectorV Mustang Audio & Video 22 02-23-2004 09:12 PM
water pump replacement Ponycarman Pre-2005 V6 Mustang 3 01-16-2004 11:26 PM
water dripping on foot while driving Monkey Pre-2005 V6 Mustang 7 08-18-2003 05:41 PM
02:50 PM
