who is rubbing - Mustang Evolution
Old 07-16-2014, 11:22 PM   #1
who is rubbing
who is rubbing? ahh if I turn my wheel to much I can hear my tires rubbing.
TurboCobra is offline   Reply With Quote
Old 07-17-2014, 11:08 AM   #2
The_Chech's Avatar
Whats your wheel offset and tire dimensions? also how low are you in the front?
Oxford White Roush Stage 1 SN# 6925--SOLD but never forgotten!
Kona Blue GT premium - Slammed on BC's and BMR's full rear suspension
The_Chech is offline   Reply With Quote
Old 07-17-2014, 11:14 AM   #3
Well then you are too low or your tires are too wide or you have an offset that isn't right or any combination of these. I'm lowered with oversized tires but I don't rub because I went narrow up front and just big enough out back. Lots of ppl rub because they want to cram 275s up front and 315s out back for no good reason IMO.
Need more info from your combo.
Old 07-17-2014, 11:33 AM   #4
mickey Thompson's in all four corners 245/40/18 and 275/35/18
If I turn the wheel all the way and stick my hand around the wheel and feel around its not rubbing but if the surface I am on is inclined or not flat I can hear it and feel it in a way
Old 07-17-2014, 11:57 AM   #5
Yeah but how much are you lowered and what wheels are you running. what size/offset? I have a 235/45/18 on a 18x8 stock offset wheel up front and its 0 rub at full lock lowered 1.25" all around.
Old 07-17-2014, 12:05 PM   #6
Not sure of the offset but they were from americanmuscle.com so they should fit properly. 18x9 for my front two and 18x10 for the back.
Springs are cut but barely enough to notice a difference. I could only imagine what it will be like when I replace the springs. Maybe I need to remove the splash guards in my fender if that's even possible, will have to take a closer look.
Old 07-17-2014, 02:18 PM   #7
The_Chech's Avatar
I'm not sure how your rubbing I have a 265/35 r18 up front on an 18x9 +22 back space and lowered 2" and have zero rubbing at full lock. Has there been any marks on any thing like the wheel or tire its self? Or is it just a noise you hear when on an incline while turning?
Old 07-17-2014, 03:58 PM   #8
its a rubbing noise I can hear when I crank the wheel and do a tight turn or when I turn as backing down the slight incline on my driveway. If I turn the wheels all the way one way and reach in it has enough clearance. I think when the body roll along with how close the wheel is to insert inside the fender it makes it rub. Could it actually be something else? Not sure what else it would be.
Old 07-17-2014, 03:59 PM   #9
I am almost positive they are rubbing on the fender well inserts
whos used rubbing compound? Zim Mustang Audio & Video 2 08-09-2006 05:49 PM
Rubbing Scut95 1979-1995 Mustang GT 8 01-19-2006 01:17 AM
Rubbing Alchohol StreetRacer4371 The Bar 7 11-08-2004 12:53 PM
Fixed my "rubbing problem" greenflash00 The Bar 2 02-18-2004 10:51 AM
Getting some rubbing up front...any suggestions? greenflash00 Mustang Wheels & Tires 18 02-08-2004 12:42 PM
08:31 AM
