Engine build - Mustang Evolution
Old 07-18-2014, 12:14 PM   #1
Dogbitdude's Avatar
Engine build
Hey guys I'm doing a budget build right now and I'm looking for the best way to go for rotating assemblies when it gets to around 500-600 hp at the crank. Could I get away with finding a used 03-04 cobra crank or use the crank from a gt with forged everything else or is full forged the only real way to go? My budget for the build is 4500 all together. I already have the donor car I just need to drop in a complete engine. I'm building it from the bare block up
Dogbitdude is offline   Reply With Quote
Old 07-18-2014, 12:20 PM   #2
ill sell u a teksid block
TurboCobra is offline   Reply With Quote
Old 07-18-2014, 12:42 PM   #3
Cast crank that you have will hold that power fine if you keep the RPMs at or below 6500. $160 for Boss rods and $500 for the budget forged MMR pistons. So $660 plus any machine work on your cast crank. You can often find Cobra cranks for cheap though if you look, any Cobra crank from 96-04 will be forged as well as cranks out of 5 speed Machs. I was able to pick up a Teksid out of a 98 Cobra with the forged crank still in it for $250 locally if that gives you any idea on price.
Or if you want some extra insurance, don't get Boss rods and get the $299 MMR budget I beam rods as well which is probably your better bet.
Just remember, budget and 600hp do not go together... make sure your donor car has the suspension/driveline and fuel system to support that power as well as all the safety equipment.
Old 07-18-2014, 12:54 PM   #4
Dogbitdude's Avatar
What if the goal were to get around 500 instead of closer to 6? Would that be more budget friendly?
Old 07-18-2014, 07:58 PM   #5
What I listed is about as budget friendly as its going to get. Honestly, if you don't have a spare $10k lying around I would not bother with a build that will push past what the stock block/trans can hold.
Engine build ? Stubzmekenzie Pre-2005 V6 Mustang 1 10-05-2011 10:13 PM
engine build help? workmail21 1979-1995 Mustang GT 12 05-30-2011 12:47 PM
Starting to build engine. upton7 General Mustang Discussion 2 07-21-2010 06:46 PM
sourcing parts for engine build upton7 1996-2004 Mustang GT 14 02-26-2010 12:05 PM
Need engine build(er) advice. PureVenom 1979-1995 Mustang GT 22 09-17-2005 11:37 AM
06:54 AM
