Won't Shift Out Of Park - Mustang Evolution
Old 07-19-2014, 07:32 PM   #1
So my 2003 GT Auto wouldn't shift out of park today. Hmm, been down this one with other cars and it's usually the switch next to the brake pedal that gets actuated when you press down on the pedal. Some cars have 2 switches, one for the brake lights and another to activate the solenoid that allows the shift lever to move out of park.
My suspician is that the switch either loosened up or fell apart.
I've seen both on various cars.
VW Jetta/Golf are famous for this one.
Anyway, I crawl under the dash and try to press on the switch and Bazzzzammm the snap of a few sparks, a quick whiff of ozone (guess what movie that's from) and I say to myself " I think I found the problem"..
To make a long story short, (haha get it?) the way Ford routed these wires, at least in my car, will most definitely result in them chaffing and ultimately shorting out.
Both wires were showing exposed wire where the insulation was worn away.
The fix is to cut the plug out, splice in new wires using a soldering iron, putting heat shrink tubing on them and then wrapping with electrical tape.
Oh yea, route them away from any metal like the brake pedal arm
And make sure to disconnect the battery as well while working on it.
The reason I post this is that if my car did this, chances are some other folks have a time bomb waiting to explode. I would suggest crawling under there with a flashlight and doing a preemptive strike looking for chaffed wires before they fail.
Good luck !
vert03 is offline   Reply With Quote
Old 07-19-2014, 07:35 PM   #2
pics or it didn't happen
* a Christmas story
TurboCobra is offline   Reply With Quote
Old 07-19-2014, 08:15 PM   #3
* a Christmas story
Yep!
A Christmas Story.
Pics?
At 6'1" 250 lbs and 54 yo with arthritis I was happy I didn't get stuck under there and have to call the wife to pull me out!
Won't shift out of park KONABLUE3.7 2011-2014 V6 Mustang 42 03-21-2014 04:51 AM
Women Can't Parallel Park (and something about Ford's Active Park Assist) OsirisGuy The Bar 8 09-24-2009 09:03 PM
68 coupe 289 lights come on but won't turn over and headlights won't come on Sixty8 Coupe Classic Mustangs 2 03-07-2009 07:52 PM
I can't shift my 06 Mustang out of park without overriding it. What is wrong? 06GTGirl 2005-2010 Mustang GT 6 11-18-2006 03:26 PM
car wont shift out of park Kyle Pre-2005 V6 Mustang 19 06-03-2005 02:10 PM
12:41 PM
