What mods should I install next in order? - Mustang Evolution
Old 07-21-2014, 10:02 AM   #1
callofdutycarm's Avatar
I have a automatic 2004 mustang gt. What should I get done next? I know I want to start with the more cheaper mods for now. Nothing over 500 and no nos. I already installed a bigger throttle body/plenum, cold air intake, tune, flowmaster catback, and 3.73 gears.
callofdutycarm is offline   Reply With Quote
Old 07-21-2014, 10:04 AM   #2
Sterlingbeast5.0's Avatar
off road Pypes off road H-pipe. one of my favorites! I am doing Aluminum driveshaft next. Are you interested in appearance mods?
Old 07-21-2014, 10:09 AM   #3
Mostly just performance right now. Here there I had something new for appearance but right now looking for torque. Idc about beating someone on the highway going over 100 mph. More of a 0-60 times person. I like the takeoff
Old 07-21-2014, 11:04 AM   #4
Removing the cats and or long tube headers will help and sound mean.The aluminum drive shaft will help.but slightly over the $500. More powerful coils will help like the Acel.
Do you have any suspension work done? New control arms and things like that don't add HP but will definitely affect the launch
Old 07-21-2014, 12:13 PM   #5
Suspension will probably be what I add next
Old 07-21-2014, 01:41 PM   #6
Old 07-22-2014, 08:46 AM   #7
Site Sponsor
I would definitive recommend taking a look into an Upper and Lower Control Arm Kit to help get you off the line better. They're going to work hand in hand with the gears and should get you moving more effectively. If you're still looking for better starts I would look at a different set of rear tires. Let me know if you have any questions and I'm here to help!
Alex
Toll Free: 1-866-363-4591
Free Same-Day Shipping!
Old 07-23-2014, 12:32 PM   #8
Don't replace the stock uppers, you'll induce suspension bind and rear end hop, replacing the lowers is good. Suspension and a j-mod to the 4R are next and then replace the stock converter with a good aftermarket one. The 2004 automatic trans is the strongest transmission to come in any Mustang up until the 2011 transmissions released but your motor will not see 500hp safely, not without a build. 380-400 to the wheels is about as much as you want to go through the auto. That would be more like 400-425 through a stick, but HP numbers mean squat next to 1/4 times, too many ppl get caught up in a dyno slip and then get their doors blown off by a car making substantially less power.
Old 07-23-2014, 01:25 PM   #9
Like Scotty said, don't replace the uppers. Convert over to a 3 link set up using a Torque Arm. Much better.
Old 07-23-2014, 01:26 PM   #10
On a 99-04? Not close. That's 05+. They are $300-450 on 99-04.
Old 07-23-2014, 04:06 PM   #11
Missed this post. Headers are the very last thing you should do on a 2V, a better mid pipe is advisable but it doesn't need to be offroad, a good catted one will open up just as much power and will keep you legal if you live in an area that will get you smacked by cops who actually check. Aluminum driveshaft is a waste of money at this point.
The comment about Accel coils is completely incorrect. The best coils for the modular are OEM, period. Aftermarket "blaster" or "high performance" coils are no better than OEM and are often weaker. Longevity wise nothing is even in the same universe as the OEM coils. OEM is more expensive, but you can rebuild the OEM coils for $30 provided the plastic housing is still good. If not, go grab an intact one from the JY for $5 and rebuild that.
Definitely agree about the suspension like I said before though. And the Coyote guys experience just how drastic good suspension work can be. Shore up the stock stuff a bit with the BMR control arms/panhard/relocation brackets and a good set of springs/shocks/struts and you'll pickup a ****ton of time. Not as crazy on a lower powered 2V but still highly effective. Subframes should be on the list too if they are not done already. I recommend the Steedas because they include extra bracing plates that the others don't.
When modding a car from the start: (order of mods list for best results!!!) RGR Pre-2005 V6 Mustang 150 07-05-2014 09:56 PM
MODS MODS MODS! S197Miller 2005-2010 Mustang GT 28 02-10-2013 01:36 PM
Mods.....Mods.....Mods.... Srohda 2011-2014 Mustang GT 8 06-01-2012 12:50 PM
What should my next car should be: an '07/'08 Honda Civic or a 2010 Kia Soul? Berwick General Mustang Discussion 5 03-07-2010 05:31 PM
rank these mods in order of performance gain. MusclesFromBrussels The Bar 15 08-11-2003 06:22 AM
06:42 AM
