Speedo Off, but Odometer is accurate? - Mustang Evolution
Old 07-24-2014, 01:04 PM   #1
nimrod712's Avatar
Region: Arkansas
Hi all, picked up a 2003 GT a few weeks ago, and the speedo is off by around 6-7 MPH. I have checked it against two different GPSs. I was thinking I could get a programmer and fix it, but I checked the odometer, and it is dead on. Also, I ran the diagnostic tool on the dash, and the digital speedo is dead on. It is just the needle on the gauge that is off. Anybody know what might be causing this or how to fix it?
nimrod712 is offline   Reply With Quote
Old 07-24-2014, 02:36 PM   #2
Do you have white face or custom gauges
Old 07-24-2014, 04:35 PM   #3
nimrod712's Avatar
Region: Arkansas
Yep, white face gauges.
Sent from my XT907 using Mustang Evolution mobile app
Old 07-24-2014, 05:07 PM   #4
There ya go!
Old 07-24-2014, 10:14 PM   #5
nimrod712's Avatar
Region: Arkansas
Ah, did a little research on the white gauge faces, and I'm sure that's the problem. Thanks, guys!
Old 07-25-2014, 07:38 AM   #6
Also verify your tach is correct via the digital readout. Old trick we used to set the speedo is to run on the highway with cruise on and the clear plastic cover off the cluster. Once the car settles on a straight stretch of highway just stick the needle on the speedo to match the digital speedometer and there you go. You can also verify with a GPS.
Old 07-25-2014, 09:07 AM   #7
nimrod712's Avatar
Region: Arkansas
Thanks, yeah, I've verified that the digital one is dead on, so I can just use it. The tach is off by about 100 rpm too. I'll do what you recommended.
Old 07-25-2014, 09:10 AM   #8
nimrod712's Avatar
Region: Arkansas
Oh, do I need a special tool to remove the needles? Or can I just pop them off with a small screwdriver?
Old 07-25-2014, 09:44 AM   #9
Be really careful you don't scratch the gauges. Actually a fork doubles as a needle removal tool.
Old 07-25-2014, 08:20 PM   #10
nimrod712's Avatar
Region: Arkansas
Sweet, thanks!
88 GT gas gauge and speedo/odometer not working. UDLOOZ 1979-1995 Mustang GT 11 03-25-2014 06:57 AM
lost Speedo, Odometer and Accessories. MyStang96 Pre-2005 V6 Mustang 0 06-16-2013 09:34 AM
Speedo/Odometer Gears floridamba Pre-2005 V6 Mustang 5 05-01-2007 08:32 AM
Speedo works, Odometer does not.. floridamba Pre-2005 V6 Mustang 9 04-24-2007 03:02 AM
UPDATE!! BUTT DYNO SHOWS HP GAINS and is accurate Danger Dude Pre-2005 V6 Mustang 46 01-05-2004 09:43 PM
08:37 AM
