Vibration feeling - Mustang Evolution
Old 07-29-2014, 08:32 AM   #1
rollo1987's Avatar
Vibration feeling
Ok so I just started feeling a vibration feeling when I'm driving. It only happens when I'm stop and start driving. And it only happens the first few seconds I take off. It happens when I start slow then a second or two later the car drives smooth. Any ideas
rollo1987 is offline   Reply With Quote
Old 07-29-2014, 08:37 AM   #2
XSlashDashX's Avatar
Motor mounts.
Old 07-29-2014, 08:43 AM   #3
rollo1987's Avatar
But it only happens when I start to drive for a second or two. I had that issue on another mustang. That vibration was constant. This one only last when I start to drive then stops
Old 07-29-2014, 10:27 AM   #4
if you stop quick or your slowing down then hit the gas to do feel like a thud?
drive shaft or motor mounts
TurboCobra is offline   Reply With Quote
Old 07-29-2014, 10:29 AM   #5
my car does this a bit haha kind of like when the guy infronta u has subs and your var vibrates from the bass lol
Old 07-29-2014, 10:35 AM   #6
rollo1987's Avatar
I will have to check later. Took the journey to work.
Old 07-30-2014, 01:12 PM   #7
Mfore33's Avatar
Check the transmission mount also.
Old 07-30-2014, 03:51 PM   #8
Semerollin's Avatar
+100
Semerollin is offline   Reply With Quote
Old 07-30-2014, 05:30 PM   #9
Motor mounts, trans mount or the clutch is on the way out. My clutch is almost toast and it feels like a giant is shaking the car on takeoff sometimes. New clutch in the garage, too lazy to do it this weekend...
Old 07-31-2014, 08:46 AM   #10
rollo1987's Avatar
No my car is an automatic
Old 07-31-2014, 10:20 AM   #11
Check the mounts. Could also be a converter on the way out. Your converter is basically a big clutch.
Old 07-31-2014, 10:23 AM   #12
rollo1987's Avatar
I hope it's bit that.
Old 07-31-2014, 01:31 PM   #13
do you feeling a kick? like a slip once and a while?
Old 07-31-2014, 03:50 PM   #14
rollo1987's Avatar
No slip. Just a slight vibrating feeling for a slight second
Old 07-31-2014, 05:14 PM   #15
Still think its motor mounts. My old mustang did that and it was the mounts. Check and see if your motor is leaning.
Old 08-01-2014, 10:49 AM   #16
whats the best way to check motor mounts? pretty hard to see them.
I guess jacking up the cars front end would be the only way
Old 08-01-2014, 11:22 AM   #17
See if your motor is leaning is the easiest way I believe.
Old 08-01-2014, 12:06 PM   #18
rollo1987's Avatar
No it's not leaning. And normally if u have bad motor mounts you car will vibrate while stopped
Old 08-01-2014, 12:18 PM   #19
Easy one
A dick brake is hanging up. It releases after you get moving.
Old 08-01-2014, 03:10 PM   #20
Mine did not vibrate while idling. Only when i get going then it stop.
Old 08-02-2014, 02:40 PM   #21
Mfore33's Avatar
Could be a u joint
Old 08-02-2014, 06:41 PM   #22
JWorm's Avatar
I'm with ronnie. I think you have a caliper hanging up. Does the car pull to one side or the other when you first start to take off or slow down?
JWorm is offline   Reply With Quote
Old 08-02-2014, 07:35 PM   #23
That will tell if front or rear sticking
If a front caliper is hanging it will pull one way or the other when you take off until it frees up. Just take off slow and no hands on the steering wheel.
If it is a rear caliper it will just go straight with our Mustang suspensions.
The problem may or may not correct by it's self after a while.
Old 08-02-2014, 10:31 PM   #24
rollo1987's Avatar
I had a guy check it he said it felt loose in the front. I will have to check when I lift it up
Old 08-03-2014, 03:37 PM   #25
do you have a Dorman intake manifold?
2012 Mustang Cyclone, 2002 Mustang GT, 2004 F150 FX4, 1999 Ranger O/R 4x4, 2007 Harley FXDB
jefx is offline   Reply With Quote
Old 08-03-2014, 04:38 PM   #26
Its because you have a slight miss fire. My car also vibrated as if I had subwoofers lol ended up being a bad coil. spend 40 dollars and 2 minutes of your time and you should be good to go!.. even if the vibration is still there at least you will have fixed your #6 miss fire
Old 08-03-2014, 06:08 PM   #27
My car had a grindy vibration feel at take off from a stop. The name for that feeling had been nicknamed "gritty" by the member Fully Automatic, who was also experiencing this problem. Turns out, we both had Dorman intakes. I just replaced mine and the feeling/sound is gone.
Old 08-03-2014, 06:12 PM   #28
acceleration
My GT is slow and rough. is that normal?
Old 08-04-2014, 12:07 PM   #29
rollo1987's Avatar
Originally Posted by jefx View Post
I just put a dorman in a month ago. Kicking my self in the butt now for it. And I'm not sure if rock auto will take it back
Old 08-04-2014, 04:34 PM   #30
Bingo.
Old 08-04-2014, 04:45 PM   #31
rollo1987's Avatar
Rock auto won't take it back. So now I need to get 230 for a ford racing one
Old 08-04-2014, 04:58 PM   #32
HUH???!?
Old 08-04-2014, 05:16 PM   #33
i think its $205 on amazon.... plus you could resell the dorman on ebay to recoup some of your expense.
Old 08-04-2014, 08:11 PM   #34
Hi Straybullet
Rollo1987 say's this:
[QUOTEit only happens the first few seconds I take off. ][/QUOTE]
Apparently it only does it from a total stop taking off then does not do it anymore. I'm pretty certain he has a disc brake hanging up.
Old 08-04-2014, 08:17 PM   #35
Ronnie[/QUOTE]
Lol.
I get what your trying to say and I've had that exact problem... But Ronnie, reread your first post...
CAREFULLY.
Clutch catching feeling jjsg09 1996-2004 Mustang GT 4 05-10-2011 10:27 AM
Clutch Feeling Sponge-like 19Delta Pre-2005 V6 Mustang 10 04-14-2009 01:07 PM
Feeling it... MarkuzLS1 The Bar 10 10-15-2007 09:30 AM
Are you feeling depressed and feel like you have no life? Seph The Bar 30 11-01-2006 12:21 PM
V8 feeling strike1980 Pre-2005 V6 Mustang 10 05-19-2006 06:22 PM
12:12 AM
