Window too tall? - Mustang Evolution
Old 07-29-2014, 05:10 PM   #1
SquatchMan's Avatar
Window too tall?
The window on my passenger side door hits the top of the car when I shut it. Any way to fix this? The car has never been wrecked to my knowledge.
04 GT
04 GT
SquatchMan is offline   Reply With Quote
Old 07-29-2014, 05:26 PM   #2
JoeyM91's Avatar
04 GT
Did you disconnect the battery recently?
Old 07-29-2014, 05:28 PM   #3
SquatchMan's Avatar
I didn't. But I just bought the car.
04 GT
04 GT
Old 07-29-2014, 05:31 PM   #4
JoeyM91's Avatar
Try rolling them all the way down, then disconnect the battery, wait about 5 minutes, reconnect it. Start up the car and let it sit a minute and then try rolling them back up with the door closed.
I had a similar issue after reconnecting my battery. I had my door open and the window went up too far.
Old 07-29-2014, 05:33 PM   #5
SquatchMan's Avatar
Ok, will do. I'll letcha know how it goes.
04 GT
04 GT
Old 07-29-2014, 05:59 PM   #6
SquatchMan's Avatar
No dice...
04 GT
04 GT
Old 07-29-2014, 06:03 PM   #7
Mile high JDF's Avatar
The windows on a new edge don't roll down slightly when you open the door like they do on your car.
OP, with the door closed as best as you can get it, look at the gap between the top of the door compared to the bottom do it from an angle kind of similar to this (see picture) and see if the top or bottom sticks out more than the other.
- Silver 2007 Corvette
Current - DHG 2001 Bullitt
Old 07-29-2014, 06:10 PM   #8
SquatchMan's Avatar
The door shuts, it just rubs the top trim. I'm worried that somebody will slam it and shatter the glass.
04 GT
04 GT
Old 07-29-2014, 06:13 PM   #9
SquatchMan's Avatar
Name:	ImageUploadedByMustang Evolution1406679170.758719.jpg
ID:	162488where my finger is at is the only place it rubs.
04 GT
04 GT
Old 07-29-2014, 06:37 PM   #10
Look in the 04 GT window thread right below this one...
Old 07-29-2014, 06:56 PM   #11
SquatchMan's Avatar
Door was open
04 GT
04 GT
Old 07-29-2014, 07:01 PM   #12
The window adjustment procedure is in cliffyk's post in the other thread.
Old 07-30-2014, 12:31 AM   #13
Mfore33's Avatar
I have this problem on the driver side of my car. It is a part that is glued on the front and back of the window and mine fell off. I bet if you pull the door panel off you will find it in the bottom of the door or about to fall off the window.
Old 08-02-2014, 02:09 PM   #14
SquatchMan's Avatar
It didn't work.
04 GT
04 GT
Old 08-02-2014, 02:10 PM   #15
SquatchMan's Avatar
Did you get yours replaced? Or what did you do? Mine is the same way.
04 GT
04 GT
Old 08-02-2014, 02:25 PM   #16
You did it exactly like the instructions say and it still doesn't want to stop in the correct "up" position huh?
In that case, as was mentioned previously, I would start looking closer at the regulator mechanism because there must be something either broken or fell off of the mechanism that stops the window from going up too high.
Old 08-02-2014, 02:38 PM   #17
Mfore33's Avatar
There are two metal brackets that are on the front and back of the window. Both are used as the rail guide and part of the stop system. The other part of the stop system is the L shaped bracket held on by the gold colored bolts at the top of the door frame. The part that came off on my car was the bracket/guide that is glued on the back side of the glass. It is a black painted part. The glass sits in a channel and a guide wheel is bolted on that slides in the rail for the lift arm. Then the windows goes up the guide had come loose from the glass it wouldn't stop the motor and it would go too high and hit the frame of the roof. I used a two part epoxy that holds up to 3200 lbs (according to the package) and glued the black bracket back on to fix it. Best of luck to you fixing it. The only other thing to do if you can't find a glue strong enough to hold it is to get a new window with the brackets intact from a junkyard or from ford. Maybe you could go to a glass speciality shop and see if they have a good glue to use.
Old 08-02-2014, 02:46 PM   #18
Glass shops have that adhesive.
Old 08-02-2014, 03:16 PM   #19
SquatchMan's Avatar
That's what it was. Adhesive was completely gone, the front one looked brand new but the back was destroyed. Just filled it full of silicone, hopefully that will work.
04 GT
04 GT
Old 11-28-2014, 12:14 PM   #20
SquatchMan's Avatar
Worked great. It's been like 3 months now since I filled it full and it's still going strong.
04 GT
04 GT
Door window too tall? SquatchMan 2005-2010 Mustang GT 1 07-29-2014 05:14 PM
Too tall for the Stang? rmattsmith General Mustang Discussion 40 04-07-2014 11:14 PM
Gear Options with MT82, Boss IM and Tall Tires Napoleon85 2011-2014 Mustang GT 2 04-22-2012 06:44 PM
How tall of a tire should i use for 3.73's 20115oh 2011-2014 Mustang GT 3 04-09-2012 10:22 PM
Any good Sports car for big & tall drivers? eder General Mustang Discussion 4 04-04-2010 07:34 AM
11:43 PM
