Adjust Raxiom Smoked Projectors - Mustang Evolution
Old 08-02-2014, 05:06 PM   #1
SquatchMan's Avatar
I've got the "Eagle Eye" edition of the Raxiom smoked projector headlights, how far away from a garage door or wall do i need to be to adjust them properly? Right now, they point almost straight down, so I can't see worth a crap. But I also don't want to be "that guy" who blinds everyone with their HIDs.
SquatchMan is offline   Reply With Quote
Old 08-02-2014, 06:04 PM   #2
Steve96's Avatar
I believe late model restoration has a how to video for this on their site.
1996 GT
Old 08-02-2014, 06:17 PM   #3
There are also instructions and specifications for headlight adjustment in the owners manual.
Old 08-02-2014, 06:21 PM   #4
SquatchMan's Avatar
ok, thanks!
Old 08-02-2014, 07:47 PM   #5
SquatchMan's Avatar
How do I actually adjust them? Where are the screws? The ones that are on there don't do crap to actually move the beams one way or the other.
04 GT
Old 08-02-2014, 09:52 PM   #6
Steve96's Avatar
They make a wrench specifically for adjusting them that may make it easier
---------- Post added at 10:52 PM ---------- Previous post was at 10:52 PM ----------
Their a pain in the a$$
1996 GT
Old 08-02-2014, 09:54 PM   #7
SquatchMan's Avatar
Yeah I'm prolly just gonna go to smoked oem
04 GT
04 GT
Old 08-02-2014, 10:33 PM   #8
The stock headlights adjust with a Philips screwdriver. There is no side to side adjustment, only up and down.
Old 08-02-2014, 10:46 PM   #9
The special wrench tool that was mentioned is only for foxes or 94-98 cars. The 99-04 lights adjust with a screwdriver or should, the OEM ones do.
Anyway, the procedure to adjust the height is simple. Measure how far from the ground the center of the projector is. At 25 feet away from a wall on a level surface, the cutoff should be 2 inches below that number. So at 25 feet if you are 24" off the ground the cutoff should be at 22" just as an example.
Hopefully the Raxioms provide a clean cutoff, if not, I would not run HIDs.
Old 08-03-2014, 07:02 AM   #10
SquatchMan's Avatar
The very peak of the headlights (when adjusted all the way up) is still way too low to be able to see safely. I'm almost reduced to sticking something underneath the headlights to prop them up in order to see.
04 GT
04 GT
Old 08-03-2014, 08:44 PM   #11
04 GT
Honestly, from what I have seen in person... Raxiom stuff really looks low quality. Maybe I need to see more of it or see some of the Coyote stuff but the NE stuff looks like something a ricer would have on his civic, at least IMO. I've got aftermarket projectors on my 98 but they are DEPOs and its ashame DEPO does not make anything for the 99-04.
Honestly, the very best option for a 99-04 car is a set of brand new or refurbished OEM headlights retrofitted with a Morimoto HID projector kit. You can also try the stock housings with a really good Halogen like an Osram (not sylvania) Silverstar or a Philips Xtreme bulb.
Old 08-03-2014, 08:53 PM   #12
SquatchMan's Avatar
Where would I get a HID projector kit?
04 GT
04 GT
Old 08-03-2014, 09:18 PM   #13
The Retrofit Source Inc
You can also google HIDGUY to get them done so you don't have to. It's not cheap but its the best.
Old 08-03-2014, 09:27 PM   #14
SquatchMan's Avatar
Ok thanks!
04 GT
04 GT
Old 08-06-2014, 08:36 PM   #15
dougpost12's Avatar
Hey guys im actually having the opposite problem. My headlights raxioms are aimed so high that they are actually higher than the stock high beams. My problem is that i have the headlights adjusted so far down that the screws in the back used to aim them are actually hitting the metal of the car behind the headlights. How can i pull the lights down more? Can i just cut the screws and if I do how much more screw is left? I need to pull the lights down about a foot atleast.
dougpost12 is offline   Reply With Quote
Raxiom projectors XSlashDashX 1996-2004 Mustang GT 15 07-08-2013 05:37 PM
Raxiom projectors with switchbacks GBrownie86 2011-2014 Mustang GT 3 07-03-2013 02:27 PM
For Sale: FS: 10-12 Raxiom Smoked Projectors w/HIDs thejohncarlson Mustang Parts for Sale and Wanted 3 05-09-2013 01:29 PM
Raxiom projectors or HID kit Rykenknight 2011-2014 V6 Mustang 25 12-09-2012 08:39 AM
Projectors or no Projectors 1quikV6 Mustang Audio & Video 9 11-14-2006 10:03 AM
11:51 PM
