04 GT won't start - Mustang Evolution
Old 08-03-2014, 06:26 PM   #1
DuffieNY24's Avatar
04 GT won't start
So I'm not sure where else to go. I replaced my crank sensor, can sensor, spark plugs, coils, fuel pump, lines, rails, injectors, fpdm. Fuses are fine, INERTIA SWITCH IS NOT THE PROBLEM. I feel the need to express that for the many people that will say it anyways. My key is being recognized. I'm at a damn loss here. Any input is welcomed
DuffieNY24 is offline   Reply With Quote
Old 08-03-2014, 06:33 PM   #2
What does it do? does it crank over?
2012 Mustang Cyclone, 2002 Mustang GT, 2004 F150 FX4, 1999 Ranger O/R 4x4, 2007 Harley FXDB
jefx is offline   Reply With Quote
Old 08-03-2014, 06:35 PM   #3
fuel, spark, and compression are the three things needed for it to run. Where do you suspect the problem to be and why?
Old 08-03-2014, 06:38 PM   #4
DuffieNY24's Avatar
Cranks but won't start. And I'm not sure. I'm pretty sure it's not the fuel though lol
Old 08-03-2014, 06:38 PM   #5
Are the plugs sparking?
Old 08-03-2014, 06:39 PM   #6
DuffieNY24's Avatar
Yea it has spark
Old 08-03-2014, 06:40 PM   #7
is it an auto?
Old 08-03-2014, 06:40 PM   #8
yah telling us what it does when you turn the key would be better then clarifying that it is NOT the inertia switch lol . Could be a dead battery, starter could be done who knows without knowing what its doing.
TurboCobra is offline   Reply With Quote
Old 08-03-2014, 06:41 PM   #9
how did you test the spark?
Old 08-03-2014, 06:42 PM   #10
DuffieNY24's Avatar
Pulled the plug and coil, crank and looked at sparks come out..
Old 08-03-2014, 06:44 PM   #11
DuffieNY24's Avatar
Sorry turbo lol. I've been dealing with this for a while and everytime... Did you check the inertia switch? Lol
Old 08-03-2014, 06:48 PM   #12
Pull off the air intake at the throttle body and spray some starting fluid into the throttle body. If it starts, or tries to start you'll know that it is fuel related.
Old 08-03-2014, 06:56 PM   #13
DuffieNY24's Avatar
I'll try it tomorrow. About how much is it?
Old 08-03-2014, 06:58 PM   #14
a can of startin fluid is a couple bucks
Old 08-03-2014, 07:00 PM   #15
the correct procedure for starting fluid is to have one person crank the engine while someone else sprays into the plenum at the same time. If it doesnt hit after a few seconds, give up. too much ether can be bad for the engine.
Old 08-03-2014, 07:04 PM   #16
DuffieNY24's Avatar
Ok. I'll try it tomorrow am
Old 08-03-2014, 07:06 PM   #17
Just a quick thought... is it possible you could have cross wired a couple COPs?
Old 08-03-2014, 07:10 PM   #18
DuffieNY24's Avatar
No I did them all 1 by 1
Old 08-03-2014, 07:13 PM   #19
what was the situation when it started acting up? was it running fine, then one day it just wouldnt start? or was it giving any warning signs to a problem and/or a CEL?
---------- Post added at 08:13 PM ---------- Previous post was at 08:12 PM ----------
any codes?
Old 08-03-2014, 07:18 PM   #20
DuffieNY24's Avatar
It gave a cel code for the fuel pump. I replaced it, it started, drove it about a 1/4 mi and it stalled
Old 08-03-2014, 07:19 PM   #21
DuffieNY24's Avatar
But it doesn't give any cel or dtc codes
Old 08-03-2014, 07:25 PM   #22
Have you checked the fuel pressure?
2004 GT - Bama SCT Tuner - Pypes catted X-Pipe - Pypes Violator Catback
- Comp XE270AH - DIY Sequential Turn Signals in the works!
ltdan is offline   Reply With Quote
Old 08-03-2014, 07:26 PM   #23
DuffieNY24's Avatar
Yea 46
Old 08-03-2014, 07:54 PM   #24
Well this is starting to get interesting.
So it has both spark and fuel pressure? (Rhetorical)
When you turn the key to the "on" position does the Check Engine Light illuminate along with all of the other warning lights?
Old 08-03-2014, 08:03 PM   #25
DuffieNY24's Avatar
Yea it lights up and goes off with the rest of them lol
Old 08-03-2014, 08:10 PM   #26
Do you remember what the code was exactly? Did it have anything to do with the fuel pressure sensor?
Old 08-03-2014, 08:12 PM   #27
DuffieNY24's Avatar
No. First it was the fuel pump, then the fpdm
Old 08-03-2014, 08:28 PM   #28
When you were cranking it over trying to start it, could you smell any fuel coming from the exhaust or anywhere?.
If it has fuel pressure to the rails and spark and I'm assuming compression it should start or at least try to start. It seems like the fuel injectors aren't functioning maybe.
Oh well, try the starting fluid and that will verify if it is indeed getting spark or not.
Old 08-04-2014, 05:38 PM   #29
DuffieNY24's Avatar
Name:	ImageUploadedByMustang Evolution1407195469.456767.jpg
ID:	162870this the right stuff?
Old 08-04-2014, 05:47 PM   #30
That's the stuff.
Old 08-04-2014, 05:48 PM   #31
DuffieNY24's Avatar
It's still not starting -____-
Old 08-04-2014, 05:52 PM   #32
It must not be getting any spark then.
Can you smell a raw gasoline smell from the exhaust?
Old 08-04-2014, 05:56 PM   #33
DuffieNY24's Avatar
It's sparking. I looked at it spark myself
---------- Post added at 06:56 PM ---------- Previous post was at 06:55 PM ----------
No. No fuel smell. Just this damn starter fluid on my hands
Old 08-04-2014, 06:02 PM   #34
It didn't even make a pop with the starting fluid huh?
In that case, since you verified that it has spark, and you just gave it some fuel, you're going to have to do a compression test because that is the only thing left that could possibly be wrong.
Old 08-04-2014, 06:13 PM   #35
Are ALL the plugs sparking?
68 coupe 289 lights come on but won't turn over and headlights won't come on Sixty8 Coupe Classic Mustangs 2 03-07-2009 07:52 PM
ooooooook, so engine won't start jimmy_beaner Pre-2005 V6 Mustang 24 11-13-2005 05:47 PM
Car won't start V6STANG007 Pre-2005 V6 Mustang 31 12-07-2004 06:07 PM
my 3.8 2001 mustang won't start sahba22 Pre-2005 V6 Mustang 7 01-19-2004 03:21 PM
10:45 AM
