Pcv help - Mustang Evolution
Old 08-05-2014, 09:22 AM   #1
ward.r's Avatar
Pcv help
Ok so the other day my dummy light came on and when i checked it it said the car was running to lean and that it was from a vac leak. I found the leak in the hosing for the pcv so i replaced all of it and pulled the pcv to check it. When i put it back in the car would die right after i start it unless someone would block off the pcv hole. So today i bought a new one as soon as i started it it started to die bt then kicked back up the rpms. Let it run about 7 mins or so and took off and now its back to just dying again. Anyone know how to fix this?? Just so you know its a single port pcv because i have a cold air intake so it only attaches to my intake mani and it screws into my valve cover
Sent from my SAMSUNG-SGH-I537 using Mustang Evolution mobile app
ward.r is offline   Reply With Quote
Old 08-05-2014, 12:28 PM   #2
Try disconnecting the battery for 15 minutes to clear the computers memory so it can relearn the new idle trim. It may have learned the idle with a giant vacuum leak and now that you fixed it, it's wanting to idle too low.
Old 08-06-2014, 03:56 AM   #3
I had a similar problem, turned out I had a slugged up iac valve.
Sent from my SPH-L710 using Mustang Evolution mobile app
19robby2 is offline   Reply With Quote
plugs and pcv valve help TUNE UP Mustangman705 1996-2004 Mustang GT 1 09-19-2013 02:53 PM
PCV OR NO PCV ?????????? rick978 1979-1995 Mustang GT 13 02-24-2012 11:42 AM
95 5.0 pcv valve ? plz help asap durtyred69 1979-1995 Mustang GT 5 02-01-2012 11:04 PM
PCV delete kit breathers 97Stallion Mustang Parts for Sale and Wanted 0 09-04-2004 02:32 PM
PCV, 99+ exhaust tips, misc brackets. 1995whitestang Mustang Parts for Sale and Wanted 1 08-25-2004 06:58 PM
09:44 PM
