Cylinder 6 misfire help - Mustang Evolution
Old 08-06-2014, 10:26 AM   #1
rollo1987's Avatar
Ok so I have had a lot I help on this topic. But need to ask this question. The other day I was diagnosing this issue of my car stalling. Me and a mechanic was on the issue of the maf was bad. So we were disconnecting and reconnecting it while vehicle was running. Read the codes. And it pulled up misfire cylinder six as a pending code. I clears the code. Drove it around. No pending code has piped up again. Took spark plug out. It looks brand new and boot a spring look good too. My ? Is would me messing with maf cause that code to pop up. I have two options I'm about to do. Say f it and do a complete tune up and or send it to a mechanic that I know had 20 years experience that helps soldier on my bass. Any of your advise would be great.
rollo1987 is offline   Reply With Quote
Old 08-06-2014, 01:57 PM   #2
I already told you what to do a few times
TurboCobra is offline   Reply With Quote
Old 08-06-2014, 02:23 PM   #3
rollo1987's Avatar
I checked those. And I don't want to be throwing parts in car not knowing if it's the right one. I'm in the military. I don't make enough to be doing that lol
Old 08-06-2014, 02:29 PM   #4
rollo1987's Avatar
I wrote a long explanation to ask if me messing with the maf would pop up that code. Cause I'm not popping up a code anymore
Old 08-06-2014, 02:36 PM   #5
car still shakes and wants to stall out?
if it threw a code for miss fire its more then likely a slight misfire. or something related. And based on what your having issues with.. seems more then likely the cause. Go to a junk yard if you cant afford 40 dollars and take a coil from one of the mustangs or crown vics.
Maybe someone else will throw in there opinion on it. But I have no idea why you would try and fix every part other then the one it is telling u it is lol especially how its probably the easiest part to change
Old 08-06-2014, 02:45 PM   #6
rollo1987's Avatar
No your right it is an easy part I took it off last night. Ok if I take it off sould I just do te one or all.
Old 08-06-2014, 03:21 PM   #7
parkerz28's Avatar
Or you could swap the cylinder six cop with another cylinder then you would know if it's the cop free and easy... Thank me latter
Sent from the back seat
parkerz28 is offline   Reply With Quote
Old 08-06-2014, 05:31 PM   #8
JHghers's Avatar
+1 parker
"When a man opens a car door for his wife, it is either a new car or a new wife!"
JHghers is offline   Reply With Quote
Old 08-06-2014, 05:35 PM   #9
rollo1987's Avatar
I'm going to try that when I get home.
Old 08-06-2014, 06:12 PM   #10
How would switching it to a different cylinder show him if its the cop or not? The check engine light doesn't go off every time.
wouldn't that just move the problem to another cylinder?
or if its not even the cop wouldn't he still have the same issues he's having now? resulting in still not knowing what's wrong.
Or spend 40 bucks put the part on and if the problem stops perfect
if it doesn't well you have a coil for when one does go bad eventually.
Old 08-06-2014, 06:23 PM   #11
Turbocobra has been right on the money with needing a new cop. However, if the code is intermittant, i personaly doubt that its the cause of ALL your problems..... but ive been wrong before..
Swapping coils will tell you if the coil is bad if the misfire code follows the coil.
FWIW, you can take a chance on el cheapo COPs on ebay for about $8 a piece. They have a high failure rate, but if you are pinching pennies, its better than nothing. Just buy more than one, in case you get one thats DOA. Its not the "correct" solution, but at that price, it may be worth experimenting with.
2012 Mustang Cyclone, 2002 Mustang GT, 2004 F150 FX4, 1999 Ranger O/R 4x4, 2007 Harley FXDB
jefx is offline   Reply With Quote
Old 08-06-2014, 09:19 PM   #12
Or you could take a look at Rockauto. They probably have something within your budget.
I also have a 5% discount code. If you or snyone else is interested, I'll post it.
Old 08-06-2014, 10:39 PM   #13
rollo1987's Avatar
Thanks everyone for your input. I can be stubborn sometimes. So sorry for that. I was told by experience mechanics it was the iac and TPS changed them both. Car is running better but still does it. That's why i was iffy about buying more parts. I got this car at a good price. And I'm not close to spending what it is worth. I am also pinching pennies right now also. But I will try and just buy the cop and test that out. I think I saw one for like 20 on rock auto. Any suggestion on which one to by in rock auto.
Old 08-07-2014, 05:27 PM   #14
The only COP that I can recommend, in good conscience, is the Motorcraft.
I wouldn't even know which would be second best.
Here's the Rockauto discount code though...
2422569122511173
Enter it in the "How did you hear about us" line of the shopping cart and then click the apply button.
Old 08-07-2014, 07:24 PM   #15
mine is some cheap one but has a year warranty and fixed my issue so whatever. changing one cop with a generic one isn't going to affect the power in my car.
Actually it restored a lot of lost power. My car must have had a slight miss for a while now because after I changed the cop it runs better then I ever thought it would in its current condition.
Old 08-07-2014, 09:33 PM   #16
rollo1987's Avatar
Yea I'm going to look tonight and buy one. Hope it comes in before I go out to the field for ten days
Old 08-07-2014, 09:37 PM   #17
rollo1987's Avatar
How much does one normally cost. I was looking at the site the other night. Is it one assembly or in parts. Got kinda confused.
Old 08-07-2014, 11:13 PM   #18
rollo1987's Avatar
Old 08-07-2014, 11:20 PM   #19
They range from about $15 for the cheap ones to $42 for the Motorcraft.
They are the complete coil.
Sent from my SAMSUNG-SGH-I747 using Mustang Evolution mobile app
Old 08-08-2014, 02:29 AM   #20
Just an example
Old 08-08-2014, 02:31 AM   #21
http:// http://www.ebay.com/itm/120960148926?nav=SEARCH
Old 08-09-2014, 02:27 PM   #22
rollo1987's Avatar
Well just bought the part. Now gota wait till prob wed. Let's see what happens
Cylinder 6 Misfire! Help! FORDGT14 2011-2014 Mustang GT 29 06-12-2013 10:56 PM
Cylinder #2 misfire. storieddeth 2005-2010 Mustang GT 10 09-26-2012 07:33 PM
2000 dodge caravan cylinder 5 misfire Niko Brown General Car Discussion 1 08-27-2012 06:44 PM
Cylinder 1 Misfire? stew99 Pre-2005 V6 Mustang 3 11-02-2011 10:31 PM
Misfire cylinder #1 with Check Engine Light JRMustang Pre-2005 V6 Mustang 29 03-14-2011 11:49 PM
04:25 PM
