Help - Mustang Evolution
Old 08-06-2014, 03:55 PM   #1
Jpalm35's Avatar
Help
My steering seems way loose and the rear end is kind of loose feeling what could it be I'm already about to change all shocks and struts anything else
Jpalm35 is offline   Reply With Quote
Old 08-06-2014, 06:33 PM   #2
JHghers's Avatar
Loose in steering than change inner and outer tie rods.
"When a man opens a car door for his wife, it is either a new car or a new wife!"
---------- Post added at 05:33 PM ---------- Previous post was at 05:33 PM ----------
And alignment
JHghers is offline   Reply With Quote
Old 08-06-2014, 09:02 PM   #3
When I said the entire front end, that is exactly what I meant... EVERYTHING!
Control arm bushings.
Ball joints.
Tie rods.
Sway bar bushings.
Steering rack bushings.
Strut bushings.
Struts.
Wheel bearings.
With the miles on your car, everything has to be worn out. I'd just replace all of the components at once and then get it aligned.
Old 08-06-2014, 09:21 PM   #4
JHghers's Avatar
I must of missed something, but if you have high milage it maybe time to look into rebuild.
Old 08-06-2014, 10:17 PM   #5
Jpalm35's Avatar
Engine and trans has been rebuilt less than 10,000 miles ago so I'm clear on that end
Old 08-07-2014, 12:34 AM   #6
XSlashDashX's Avatar
Papers to prove it was rebuilt? But check your bushings in the rear. And get alignment done.
Old 08-07-2014, 08:07 AM   #7
Front end, do everything straybullit said. Your car is super old, the whole suspension is going to be shot.
Out back, new shocks/spings/isolators/UCA bushings, Steeda or MM control arms and check to make sure your sway bar is even there. They were known to snap on some SN95s (happened to my Cobra) and the PO could have just removed it vs buying a new one. Even with a fresh rearend with a good set of LCAs, the rear isn't exactly great in a Mustang until you convert it to a 3 link or put in an IRS with a good bushing kit.
2000 Mustang GT Steeda #0048
Old 08-07-2014, 08:46 AM   #8
Jpalm35's Avatar
I have all paperwork on both rebuilds and warranties have been transferred to me. The shocks on the rear are bad and need to be replaced also I am going to check my rear end this weekend as for front end all ready ordered the parts for re doing it and am just waiting on them to be delivered was not cheap but not to bad. It's a project and not my daily driver so I can take my time and get it right
Old 08-07-2014, 09:05 AM   #9
From the pics you posted there looks like there are some rust stains on the paint which leads me to believe that the undercarriage may need a little cleaning... or worse... Make sure you don't have a cancer patient before dumping too much into it. If the driveline is newly rebuilt, this would make a great donor car for a lower mileage V6... or a clean 4 banger fox. A bolt on ModFox is a 12 second car easy because they are so damn light.
Old 08-07-2014, 09:36 AM   #10
Jpalm35's Avatar
No cancer really but it had a really bad paint job done to it it a Louisiana car never been north. Rust was the first thing I checked
Old 11-11-2014, 02:35 PM   #11
madman99's Avatar
Can someone please tell me what this tab does on a 2000 gt steering Column and can I remove it ?Click image for larger version
Name:	ImageUploadedByMustang Evolution1415738127.582496.jpg
madman99 is offline   Reply With Quote
Old 11-11-2014, 02:56 PM   #12
I lets the key turn to the release position so you can remove your keys from the cylinder. Why would you want to remove it?
Old 11-11-2014, 02:58 PM   #13
madman99's Avatar
Ok yeah I figure it out ... Well I broke the steering column on my 99 so I got one from a 2000. The top cover that fits over the column doesn't have the hole for it I want to try n use my old stuff with the new column cause it's an Ulgy tan
Old 11-13-2014, 04:54 PM   #14
madman99's Avatar
I'm in the process of dropping my k member out of my new edge. Already have the wheels off , calipers off, strut tower bolts off from up top. My next move? Take pressure lines off the rack than jack up member b loosen bolts ? #help
Help Help Help....mustang Princehollie Pre-2005 V6 Mustang 57 03-17-2015 05:58 PM
Help Help Help....1995 mustang 3.8 Princehollie Pre-2005 V6 Mustang 4 07-03-2014 07:42 PM
Baltimore area spark plug insert!! Help Help HELP readytorockyou 1996-2004 Mustang GT 0 04-25-2010 12:37 PM
Help help- fuel pump-help! The Darkside Pre-2005 V6 Mustang 26 05-08-2009 02:45 PM
Help help help? Seph Mustang Audio & Video 6 02-15-2004 05:35 PM
08:14 AM
