I have problem with my car the oil pressure is low - Mustang Evolution
Old 08-07-2014, 09:27 PM   #1
Name:	ImageUploadedByMustang Evolution1407468469.930381.jpg
Mich is offline   Reply With Quote
Old 08-07-2014, 09:57 PM   #2
escottcarp's Avatar
You know someone will ask if you have oil in the engine........
Have a great day!
escottcarp is offline   Reply With Quote
Old 08-08-2014, 01:50 AM   #3
Yes less than a month I did the oil
Change
Old 08-08-2014, 01:57 AM   #4
The dipstick is not low
Is normal
Old 08-08-2014, 07:04 AM   #5
Mfore33's Avatar
The sending unit could be bad. Does it sound normal? Maybe the filter you put on failed somehow and is blocking oil. That would be a easy thing to replace first.
Old 08-08-2014, 07:10 AM   #6
Sending unit or the filter
When get warm te car gauge go normal
Old 08-08-2014, 07:14 AM   #7
Mfore33's Avatar
Change the filter and pour out the oil from the filter to check for metal shavings. If the oil looks normal it could be a bad sending unit or a bad gauge. I had the fuel gauge on my 97 Taurus sho go bad.
Old 08-08-2014, 07:20 AM   #8
I will do that thanks
Old 08-08-2014, 08:04 AM   #9
Hey but can I used the car like that or no
Old 08-08-2014, 08:29 AM   #10
You need to find out if there is oil pressure or not first. This is the problem with the stock gauge, it doesn't tell you anything other than if you have 6+ psi or not. It is literally an on/off switch.
However, if your pump has failed and there is no pressure, no you can't use the car like that. You'll blow up your motor running it with no oil pressure.
Old 08-08-2014, 08:40 AM   #11
When start the car and let 4 to 5 minutes to warm up the pressure come to nomal
Old 08-08-2014, 10:09 AM   #12
Replace the sending unit and see what it does. That is a cheap/easy troubleshooting step. Best practice is to have an aftermarket gauge though... the stock cluster stuff is called "idiot gauges" or "idiot lights" for a reason. They are not accurate at all really.
Old 08-08-2014, 11:07 AM   #13
Thanks man
Old 08-08-2014, 11:24 AM   #14
I see this happen on cars in the winter that have used thick oil.
What oil did you use, where do you live?
If you restart the car 20 minutes after you have driven it, does the light stay off since the oil is warmed up and moving?
Does the car still run fine?
TurboCobra is offline   Reply With Quote
Old 08-08-2014, 12:21 PM   #15
What grade oil did you put in ???????????????
I have heard of this problem when people try to use 20W-50 in these engines.
I hope you used 5W-20 like the book say's.
Old 08-08-2014, 12:51 PM   #16
I live in california
And I using 10 30
Old 08-08-2014, 12:57 PM   #17
I would think as long as the pressure goes up you will be fine.
Oil pressure usually drops down at idle anyway. As long as it goes up when the engine accelerates and stays up while driving I don't think you have a problem.
If the car overheats, Then you have a problem but I don't think this is going to happen.
I'm pretty sure you should be using 5W-30 in your car. 10W-30 is slowing down the initial pressure when you start it up. It won't really hurt anything but you need to go back to the five weight as soon as you can.
I live in Florida where it stays hot and use 5W-20 year around.
Old 08-08-2014, 01:08 PM   #18
So when the gauge is up I can drive the car like normal
Old 08-08-2014, 01:11 PM   #19
Sorry I'm using 5w-30
Old 08-08-2014, 01:26 PM   #20
Yes
When it is hot out you will see the pressure drop at idle, then when you rev it up a little the pressure will go up. My 2012 does the same thing.
If the needle on the Gage goes all the way down you may need to replace the sending unit. They are cheap and easy to change. I'm sure your is not dropping all the way down just at idle.
Old 08-08-2014, 01:31 PM   #21
You don't know where is located the sender unit
Old 08-08-2014, 01:33 PM   #22
No it just when the car is cold
When the car get warmer the gage go. Up normal
Old 08-08-2014, 03:35 PM   #23
Tyoung68's Avatar
If you really have no oil pressure your engine would be making a hell of a racket. If its not, then id put a new oil sending unit in cant be more than 20$ and if that didn't fix it get a manual one and hook it up to see if your gauge is bad and if all that fails then id drain the oil through a paint filter and see if there is any metal shavings. If not then go buy the cheapest oil run some engine oil cleaner through it for a couple days drain the oil and fill it up again with the cheap stuff and if that doesn't fix it then id do oil pump
Old 08-08-2014, 04:13 PM   #24
Tyoung68's Avatar
A manual oil pressure gauge that is. You can get them at many auto part stores for cheap. I know we sell them at autozone for around 25$
Old 08-08-2014, 04:52 PM   #25
This happened to me. My gauge went up and down constantly. It was the gauge itself malfunctioning. There was oil pressure and I replaced the sending unit twice.
Eventually the whole gauge cluster stopped working and I had to replace it. Now the oil pressure gauge moves all the way over to the right. It's weird.
Evan02 is offline   Reply With Quote
Old 08-08-2014, 09:08 PM   #26
He has no problem at all
Like he say's:
It is working just fine.
Old 08-08-2014, 09:18 PM   #27
Does any one know where. I can find the oil sender unit
Old 08-09-2014, 05:06 AM   #28
An auto parts store
Old 08-09-2014, 09:45 PM   #29
When I removed the oil sending unit
It was licking a lot oil from there
Is the nomal
Old 08-09-2014, 10:32 PM   #30
Tyoung68's Avatar
Is the nomal
No
Old 08-09-2014, 10:34 PM   #31
You know what's the problem
Old 08-10-2014, 06:51 AM   #32
Did you buy a new sending unit ?????????
Was it the old one that was leaking??
Or is it the new one ??
Old 08-10-2014, 07:49 AM   #33
When I remove the old one from the hole lick a lot oil
Old 08-10-2014, 09:09 AM   #34
No problem there
Just wipe off the oil.
Screw in the new sender.
Hook up the wire
Wipe around the sender if any oil
DONE.
PS: I had a 1998 Corvette and the oil sending unit was under the intake manifold. It was a freakin nightmare to replace when it went bad. One of GM's better ideas DUH!!!!!
Old 08-10-2014, 09:13 AM   #35
Yes I did That think the sending unit fix the problem I try today and the oil pressure gauge go up normal
But when I remove the old sending unit it was trowim a lot oil from the hole is the normal or not
Low oil pressure. theweekday 2005-2010 Mustang GT 0 08-07-2014 08:35 PM
Low Oil Pressure Chaunceton Classic Mustangs 15 12-28-2012 03:37 PM
79 5.0 oil pressure problem! 79fordsky 1979-1995 Mustang GT 3 03-12-2012 01:48 PM
Oil Pressure Guage Problem FORDGT14 1996-2004 Mustang GT 6 03-03-2012 06:54 PM
07:46 PM
