plasti-dip help! - Mustang Evolution
Old 08-08-2014, 04:37 PM   #1
zoneo's Avatar
plasti-dip help!
hey guys
so i keep trying to plasti dip different parts of my car (doing the hood now) but everytime i do it i run into the same problem.. when i go to peel the tape, the paint peels with it and my clean lines end up looking ragged. my friend told me to peel it while its wet, but its like almost an instant dry so i dont see how you could do an entire coat and peel it off before the paint drys... how do you guys do it??
zoneo is offline   Reply With Quote
Old 08-08-2014, 04:39 PM   #2
Peel it when it's wet, it's the only way
Evan02 is offline   Reply With Quote
Old 08-08-2014, 04:40 PM   #3
zoneo's Avatar
does that mean i have to redo the coat i just did?
Old 08-08-2014, 04:48 PM   #4
You should be fine if you only did 1 or 2 thin coats. But the last coat you have to lay on thick and peel the tape quick
Old 08-08-2014, 05:05 PM   #5
The_Chech's Avatar
The way I did it is peel off the tape after a good 1st coat while it's wet, right after your done spraying and put the can on the ground then peel that bad boy off fast. Then tape 2 pieces of tape together just enough to where both have half of the sticky part showing on both sides (sorta like double sided tape but half is not sticky). Then place the tape, the bottom half should be sticky side facing you so it won't adhere to the plasti-dip on the car and peel off with the tape. Place the tape right on the now dried line so you can add more paint on your edge so its thicker. and just repeat that process so you can build up the edges layer. It takes more work but is worth it for nice lines and thickness.
Tried to make this as visual as possible so hopefully it helps.
Oxford White Roush Stage 1 SN# 6925--SOLD but never forgotten!
Kona Blue GT premium - Slammed on BC's and BMR's full rear suspension
The_Chech is offline   Reply With Quote
to plasti dip or not plasti dip ebgonzalez1 2011-2014 V6 Mustang 17 09-15-2012 03:52 PM
Plasti dip HELP ASAP TXstang125 General Mustang Discussion 28 08-08-2012 06:22 PM
Plasti dip help MustangGT02 Mustang Paint, Appearance & Detailing 14 04-03-2012 09:50 AM
Plasti Dip Help! BeasGT 1996-2004 Mustang GT 33 02-27-2012 11:34 AM
Plasti-dip your car... side job.. help needed Topless04GT Mustang Paint, Appearance & Detailing 1 01-15-2012 09:08 PM
08:41 AM
