Whinnying noise when I push in my clutch - Mustang Evolution
Old 08-09-2014, 05:47 PM   #1
Jpalm35's Avatar
I noticed today after I took it into towns that when I push in my clutch I get a whining noise I never heard or just noticed it before clutch is fairly new maybe a month or two old and has very little miles. Is it normal or do I need to adjust it or what
Jpalm35 is offline   Reply With Quote
Old 08-09-2014, 07:15 PM   #2
Only time I heard a whiney noise was in my buddys stang. His throw out bearing went out.
Try the self adjusting the clutch. Lift the clutch pedal and then press it down fully
Sent from my SPH-L710 using Mustang Evolution mobile app
19robby2 is offline   Reply With Quote
Old 08-09-2014, 07:29 PM   #3
Jpalm35's Avatar
Ok will do I thought about the throw out bearing but it just got changed along with the clutch but as we all know you can always get bad parts
Old 08-09-2014, 07:39 PM   #4
Jpalm35's Avatar
Old 08-09-2014, 11:52 PM   #5
Steve96's Avatar
Isn't that typically a sign of an issue like the clutch is going?
1996 GT
Old 08-09-2014, 11:54 PM   #6
Steve96's Avatar
Do you know if it has a new flywheel or if it was resurfaced? I don't know if this could cause this issue though.
1996 GT
Old 08-10-2014, 08:57 AM   #7
Jpalm35's Avatar
Have no idea about that but clutch is only a few months old
Old 08-10-2014, 12:11 PM   #8
Noise when you push the clutch in is sign of a bad pilot bearing. When the clutch is engaged (pedal up), the pilot and the input spin as one, when you disengage the clutch (push pedal to floor) the input spins at a different rate than the crank and that is what the pilot bearing is for. Your TOB would be making noise all the time if it was going out as a properly adjusted TOB is always spinning.
Old 08-10-2014, 06:04 PM   #9
Jpalm35's Avatar
How to I go about changing the pilot bearing and would I change the clutch and tob again at the same time
Old 08-10-2014, 07:59 PM   #10
Pilot requires the entire trans to come out as well as the clutch and flywheel. You don't have to change the clutch and TOB if they are new but if they are older you might as well while its all apart.
Clutch Pedle hard to push down? Scream 1996-2004 Mustang GT 7 08-08-2012 04:54 PM
clutch clutch... clutch Butch SVT Mustang 4 06-29-2012 03:53 PM
1989 Mustang 5.0 Clutch peddle wont push down,? deerward66 1979-1995 Mustang GT 2 12-13-2011 12:25 PM
How far can you push an engine? Seph The Bar 8 09-29-2004 12:29 PM
08:21 AM
