99 Mustang engine work - Mustang Evolution
Old 08-10-2014, 02:44 PM   #1
So i bought a 99 mustang gt 5 speed last year and am wondering whats been done to the engine. Ill list the specs and see what you guys think. Its more of identifying the engine and figuring out what it is (pi vs non pi/romeo vs windsor)
It has a 6 bolt crank
It has 13 valve cover bolts
Oil fill is on passenger side
Edges of intake ports are smooth not scalloped
Pretty sure it has a pi intake since it goes way down in the valley of the engine
It almost seems like the engine is sitting farther back than it should cuz i added an o/r x pipe and it hit the k frame right near the engine bay plus getting to the studs to bolt it up was near impossible.
I would just like to know what kind of engine it has so if i get more mods like cams in the future i know what im up against. Thanks in advance.
Sent from my SGH-I747M using Mustang Evolution mobile app
4.6gt is offline   Reply With Quote
Old 08-10-2014, 02:50 PM   #2
parkerz28's Avatar
All 99 - 2004 models of the gt where pi
Sent from the back seat
parkerz28 is offline   Reply With Quote
Old 08-10-2014, 03:06 PM   #3
Yes but im pretty sure this motor isnt stock. What im asking is what its from and if its pi or non pi and windsor or romeo. 99's are supposed to have 8 bolt cranks but this engine has a 6 bolt crank. So something has been changed
Old 08-10-2014, 03:41 PM   #4
Mile high JDF's Avatar
Strap it on a dyno and see how much power it makes. The passenger side exhaust manifold flange has always been a pain in the butt. More than likely you have a late 01 - 04 motor or a NPI shortblock with PI heads
- Silver 2007 Corvette
Current - DHG 2001 Bullitt
Old 08-10-2014, 03:43 PM   #5
Closest dyno is probably 3 hours away. But dont the pi heads have the scallopped edges on them, not smooth? How can i make sure there pi heads?
Old 08-10-2014, 03:50 PM   #6
I have no clue about that, but Google found this. http://forums.corral.net/forums/gt-s...-pi-heads.html
Old 08-11-2014, 11:40 AM   #7
To verify they are PI heads you are going to have to yank the intake. If your intake holes are round you have NPI, if they are squarish you have PI heads. 13 bolts=Windsor but there were both NPI and PI Windsors.
Since the car is a 99 and you have a 6 bolt crank... my guess is that you have the original 99 PI heads/cams/intake and a NPI bottom end. Which would be a good thing as a PI swapped NPI is actually going to make a little more power than a regular PI motor, but you have to be aware of a few things if that is the case like a higher compression and a limited cam selection.
Only way to be totally sure what bottom end it is is to pull the heads unfortunately unless you can verify it from the previous owner along with what heads you have.
Old 08-11-2014, 02:13 PM   #8
WJL
Check the casting numbers you will need a mirror if the heads are still on the car. you can Google the casting number or i think some one on this forum gave me the numbers. if you look on the right side (passenger Side the casting numbers are under the number one exhaust port.
I have the casting numbers in the garage if i get down there tonight i will send them It's High School Football season in Western PA getting to the garage has been difficult
WJL is offline   Reply With Quote
Old 08-11-2014, 02:17 PM   #9
WJL
It's a NON-PI head if the casting number begins with RF-F5AE. All PI heads begin with either:
RFXL3 or RF1L2E
Old 08-11-2014, 03:45 PM   #10
Crap looks like it has non pi heads. I remember lookingat the casting # and it started with rf f5ae. That sucks
Old 08-11-2014, 05:58 PM   #11
WJL
i'm far from an expert but i'm pretty sure you could have any combination Romeo Block w/Windsor Heads Windsor Block w/Romeo Heads, most of the six bolt flywheels indicate its a Romeo but with that being said i have heard the key word "heard" there are Windsor with six bolts IDK.
I got a set of PI heads off an 03 Explorer
For Sale: 1978 mustang II engine needs work zodo27 Mustangs for Sale and Wanted 2 10-10-2013 01:41 AM
1978 mustang II engine needs work zodo27 Mustangs for Sale and Wanted 13 09-10-2013 08:31 AM
engine work baxterbee7 1996-2004 Mustang GT 2 05-04-2005 12:25 PM
Parting out the car...selling engine work stangin99 Mustang Parts for Sale and Wanted 0 03-28-2005 07:20 PM
*DUW* Got my engine stuff, now to work on it all. n8r Pre-2005 V6 Mustang 4 07-22-2003 11:07 AM
12:49 AM
