Detonation under load? - Mustang Evolution
Old 08-10-2014, 07:36 PM   #1
I've had my car for about a year now, it's a 2002 gt with a 5 speed, now has about 80k on it.
When I first got it this wasn't a problem but now if I'm going about 40mph and put it into 5th I hear some detonation. Once I reach about 50mph it's gone. So it's pinging at low rpm's.
What can be causing this? I changed my plugs and my fuel filter, I was going to do injectors next but I read they're good for 150k and I'm way under. And I did already try running cleaner in my fuel.
Evan02 is offline   Reply With Quote
Old 08-10-2014, 07:45 PM   #2
Shawnsta's Avatar
Have you checked your timing?
Shawnsta is offline   Reply With Quote
Old 08-10-2014, 07:55 PM   #3
I thought about doing that. But the thing is, I shouldn't have to. There has to be something else going on because it was running just fine before.
Old 08-10-2014, 08:03 PM   #4
V6 stang's Avatar
If you figure it out let me know. Mine is detonating also at low rpm's. I'm thinking fuel pumps going bad. I've been told that could be the problem also, so who knows. Good luck...
Yes I edit my posts a lot, auto correct likes to sabotage me!
2012 Mustang GT Convertible
Roush Exhaust
2003 Mustang GT (Sold)
Old 08-10-2014, 09:22 PM   #5
I've been reading a bit about this problem.
You are right, if it was running without detonation before, something must have changed.
I'd start looking at everything "air delivery" related and begin with cleaning and inspecting the Mass Airflow sensor.
Also, check the air intake for leaks and all of the vacuum hoses and the intake manifold for vacuum leaks. Dont forget to clean or replace the PCV valve and inspect the grommet and hose for leaks.
After all of the air related things are checked. You'll want to turn your attention to the fuel delivery system and run a fuel pressure test.
Something is "tricking" the computer to make the engine run lean. Check all of the" free" stuff first...
Old 08-11-2014, 08:23 AM   #6
Detonation under load at about the same speed as you was one of the symptoms I had when I had a weak COP. No codes thrown but I could feel a miss at those speeds as well. Accelerating made the miss/ping disappear.
I found it by data logging with my SCT.
If you have a code reader that detects pending codes you might be able to see them there.
Just a thought if the usual suspects don't solve the problem.
vert03 is offline   Reply With Quote
Old 08-12-2014, 07:44 AM   #7
Shortly after the pinging began I replaced my intake with a Cai, in the process I cleaned everything, I will defintley check vacuum lines
Old 08-12-2014, 01:13 PM   #8
V6 stang's Avatar
That's the whole problem IMO. It could be so many different things. If you bring it to a mechanic and they start throwing parts at it.. It will expensive fast. If you have limited savings, then it will prolly eat through that pretty fast.
Roush Exhaust
04 Mach 1 stalling and occasional studder under load kevinfm91 1996-2004 Mustang GT 5 05-15-2013 10:23 AM
Shutters under load Rockpanama 1996-2004 Mustang GT 6 11-11-2012 01:42 PM
Engine popping under load Travis B 1979-1995 Mustang GT 6 07-02-2012 07:30 AM
Ticking under load MustangGT02 1996-2004 Mustang GT 13 01-18-2012 03:40 PM
Detonation or Not Detonation? SpectorV SVT Mustang 17 05-02-2011 12:40 PM
09:38 PM
