Anyone know what the hell this noise is? - Mustang Evolution
Old 08-11-2014, 04:24 PM   #1
ty98gt's Avatar
My car is making this metallic scraping noise on cold starts. It only happens if the car has been sitting for 6+ hours. It has been happening off and on for a while but it's gotten worse recently. It used to only happen in cold weather but now it's happening all the time...It only lasts for 1-2 seconds right when the car starts.
Anyone know this noise?
98 gt cold start scraping noise - YouTube
Engine/drivetrain mods: Pro 5.0 Short Shifter, Dragon Plenum-75mm, Accufab TB-70MM, K&N FIPK GEN.2 Air Intake, Bassani Cat Back Exhaust,Bassani Catted X Pipe, 3.73 FRPP Rear Gears,Ford Racing TA Rear Diff Cover,
Bunch of suspension goodies
ty98gt is offline   Reply With Quote
Old 08-11-2014, 06:38 PM   #2
I couldn't get the YT to play but if it's a grinding noise that occurs right after you release the the key from the "start" to the "on" position, it is likely the starter gear isn't releasing from the ring gear on the flywheel/flexplate right away, once the engine starts.
Old 08-11-2014, 06:43 PM   #3
ty98gt's Avatar
That sounds about right actually. As soon as the car fires up, it makes the metal grinding/scrape noise. Does that mean the starter is going bad?
Old 08-11-2014, 06:48 PM   #4
Mfore33's Avatar
Maybe or it could be a bad idle or tensioner pulley. You can take the belt off and spin each pulley and see if any one pages noise.
Old 08-11-2014, 06:54 PM   #5
Do what Mfore said also, unless you have it narrowed down to the starter.
It might be that the starter mounting bolts are coming loose, a bad starter, a bad starter solenoid, or, possibly, the ring gear on the flywheel is bad.
Old 08-11-2014, 07:01 PM   #6
ty98gt's Avatar
I'll check those out. The noise sounds like its coming from the back of the engine so at first i thought it was an internal engine problem or something with the clutch.
When the car is warm there is also this quiet rattle that goes away when I press in the clutch at idle. I wonder if its related to the cold start noise?
Old 08-11-2014, 07:05 PM   #7
What you just described is the throw out bearing. They all seem to do that eventually.
Old 08-11-2014, 07:08 PM   #8
Ok. I got the video to play.
Check the starter.
Old 08-11-2014, 07:13 PM   #9
ty98gt's Avatar
I don't think its the throw out bearing, I had a bad throw out bearing on the stock clutch set up before I got a centerforce put in about 10,000 miles ago. That bad TOB was more of a chirp or squeak. The sound now is more of metallic rattle sound. It could be something different, I just maybe thought that it could be related..
Old 08-11-2014, 07:50 PM   #10
davidr_1961's Avatar
Sounds like a bearing from an idler or wp or tensioner. Simply take the belt off and start it up. Noise gone? Figure out wich bearing and replace as needed
davidr_1961 is offline   Reply With Quote
I want to know the parts for a T-5 swap into a 77 mustang cobra 4 speed! anyone know? trenten General Mustang Discussion 2 03-11-2010 04:14 PM
Clicking Noise kind of Squeeky Noise... braumab 2005-2010 Mustang GT 23 06-29-2008 11:24 PM
I'm going to hell for laughing, I know it PureVenom The Bar 14 04-04-2008 09:18 PM
what the hell is this noise???? Zim 1979-1995 Mustang GT 13 10-05-2005 08:53 PM
Anyone know anyone that has died from Mesothlioma?(asbestos cancer) Brent The Bar 5 04-08-2004 10:37 AM
04:54 PM
