White Smoke - Mustang Evolution
Old 08-11-2014, 10:48 PM   #1
White Smoke
Hey guys I just got me a 00 GT and it started to produce white smoke when I start it while running no white smoke I went to NAPA and got the combustion tester but the fluid doesn't change color why the car is on it smells like coolent fluid. Can you guys help please.
Sick_00GT is offline   Reply With Quote
Old 08-11-2014, 11:00 PM   #2
Exhaust that smells like coolant is a sign of a blown head gasket.
Keep an eye on the coolant level and see how much it's losing. And the oil level to make sure that there isn't a milky substance in the oil.
Old 08-12-2014, 07:59 AM   #3
Thank you very much for the response I will give it a tune up and a coolent gulch and go from there it has no leaks or anything like that. But I will be watching
Old 08-12-2014, 09:28 AM   #4
rollo1987's Avatar
Yea a quick way to see if head gaskets are blown is check coolant resolver. If it's milky color. You have oil mixing in the cooling system. If not. Drain some oil and see if coolant is flowing with the oil. That would mean coolant is leaking in the engine which is worse. Happened on a hummer we were working on. I got lucky with my old mustang. Oil was just in the coolant
rollo1987 is offline   Reply With Quote
Old 08-12-2014, 10:29 AM   #5
Will take some pics and if you guys can help me that's would be great I didn't know owning a mustang came with these perks, which is Mustang Family
Sick_00GT using Mustang Evolution
Old 08-12-2014, 10:32 AM   #6
Pancakes's Avatar
White means coolant or water. Blue means oil. Black means fuel. Mine smoked white for a good few weeks after I ran seafoam through it and always smokes white after I change the transmission fluid.
I would just give it a week or two and see if it goes away. If it smells like coolant then it most definitely is a head gasket leak. Might not have blown just yet but could just be leaking.
Pancakes is offline   Reply With Quote
Old 08-12-2014, 10:40 AM   #7
Cool I'm going to try everything I will retest with the combustion tester and upload video, and will take a pic of the coolant reservoir. Thanks guys
Old 08-12-2014, 01:24 PM   #8
rollo1987's Avatar
Pancake. White can also be transmission oil. Happened to me. Leaking out the back transmission to the exhaust. Every time I got off te high way white smoke would come out from under the car
Old 08-12-2014, 01:40 PM   #9
rollo1987's Avatar
White smoke coming out exhaust greg70056 2011-2014 V6 Mustang 27 12-22-2012 10:45 PM
White smoke Surffer227 Pre-2005 V6 Mustang 5 03-15-2012 02:11 PM
White on white or white on black? Ware12 Pre-2005 V6 Mustang 28 01-20-2012 11:49 AM
white smoke when accelerating? psycho5.0 1979-1995 Mustang GT 7 04-10-2011 05:32 PM
Thick white smoke and oil everywhere...HELP!! AliceIvers General Mustang Discussion 10 03-19-2011 01:33 PM
04:16 AM
