Steering wheel has a little play - Mustang Evolution
Old 08-13-2014, 08:36 PM   #1
Tobyg77's Avatar
Steering wheel has a little play in it. It's not terrible but enough that it bothers me. I was told there is an easy fix under the drivers side dash. Can anyone confirm this "easy fix", and if so how "easy" is it?
Tobyg77 is offline   Reply With Quote
Old 08-14-2014, 01:25 AM   #2
I'm not aware of any quick fixes. The only thing under the dashboard to do would be to unbolt the steering shaft and replace it... I doubt that's your main problem though.
When I bought my Bullitt, it was probably about like your car, it wasn't horrible but it sure as hell wasn't a great driving car either. I went ahead and replaced every single component and bushing in the front end. What a difference it made! It drives like a brand new car!
Depending on the miles on your car, you may want to consider doing the same.
The main place that develops "slop" in the steering is the steering rack bushings. Particularly, the drivers side bushing which gets soaked with oil during every oil change.
If you crawl under the front end and look at the tie rods and ball joints, and see any cracked or broken grease boots, the parts will probably need replacing. Same goes for all of the bushings, the control arm bushings, for instance, may look fine... until the control arms are removed from the car.
Every one of those parts can cause a tiny amount of play which adds up to a little play by the time it reaches your steering wheel.
Old 08-14-2014, 07:12 AM   #3
Tobyg77's Avatar
Thanks. Sounds like a lot of work I can't do. What would something like that cost if it was taken to a mechanic?
Old 08-14-2014, 07:59 AM   #4
how much play? like if your sitting in your car not moving u mean u have about a quarter inch of play? or....?
TurboCobra is offline   Reply With Quote
Old 08-14-2014, 08:02 AM   #5
Tobyg77's Avatar
Yeah, maybe that. It's just bothersome.
Old 08-14-2014, 03:04 PM   #6
I did mine with, mostly, Motorcraft parts and just the parts were about $600 if I recollect. Probably another $300 or so in labor. If you can, jack up the front of the car and take a look at the steering rack bushings. They are cheap and easy to replace with only simple hand tools and you can do it without taking the whole front end apart. As I said, the steering rack bushings can cause a lot of the play in the steering.
Old 08-15-2014, 07:30 AM   #7
Tobyg77's Avatar
Ok. Thanks for the info. I'm not a diy'er but if it's easy I may try.
Play in steering Kbasham5 1996-2004 Mustang GT 2 02-25-2014 03:33 PM
Steering wheel feels a little loose 1999mustang Pre-2005 V6 Mustang 4 08-08-2013 07:04 AM
Steering wheel shaking, power steering? toro 2011-2014 V6 Mustang 3 05-04-2013 06:31 PM
Can you interchange a 1965 mustang steering wheel with a 1967 steering wheel? gruffudd91 Classic Mustangs 1 08-26-2009 04:38 PM
steering wheel play greenpony02 1996-2004 Mustang GT 2 01-04-2008 07:02 AM
12:01 AM
