03 GT showing 2 codes - Mustang Evolution
Old 08-14-2014, 01:45 PM   #1
XSlashDashX's Avatar
P1131 and P1151. Should be the 02 Sensors, correct?
Old 08-14-2014, 02:36 PM   #2
99_GRUMPY_GT's Avatar
Do you mean PO131 and PO151? I know codes that are P1131 and P1151.
PO131=O2 sensor Circuit Low Volts (Bank 1 Sensor 1)
PO151=02 sensor Circuit Low Volts (Bank 2 Sensor 1)
Usually means the O2 is on its way out on both sides. But you may be able to take the O2's out on each side and take a wire brush to eht tip of them to clean them up. Re-install them and see if the codes come back. If they do, then it is time for new ones. The Ford tech manuals calls for replacement of O2's after 65k miles. After 65k, you are waiting for them to go bad. But try the wire brush on them, also when you take them out, make sure the tips are in good order, I have seen that code when the tip feel to pieces like a broken light bulb, the inside tips are made of porcelein or ceramic material.
2015 Race Red Performance Package GT 5.0 (435hp) stock
Still in the making Updates coming soon!
99_GRUMPY_GT is offline   Reply With Quote
Old 08-14-2014, 06:52 PM   #3
Yep! That's it! Thanks and the car is sitting at 115K so it's probably time lol.
Old 08-14-2014, 08:02 PM   #4
It could be the 02 sensors but it's unlikely that both would fail and throw codes simultaneously.
Look at the cheap and easy fixes first.
Those codes are associated with the computer detecting a lean condition.
I'd clean and inspect the Mass Airflow sensor first. Also inspect the air intake for any leaks. Also, make sure that the vacuum hoses are in good condition as well as the intake manifold gaskets.
An exhaust leak before the upstream 02 sensors can also trigger these codes.
Alabamuh showing their true thoughts lowflyn The Bar 9 08-17-2010 08:56 AM
Showing Mustang pride in Jacksonville tedness Regional Mustang Discussion 11 07-05-2005 01:47 PM
Went to a Fahrenheit 9/11 showing, kicked out WhiteStang99 The Bar 25 10-30-2004 04:21 PM
Share what you have learned from showing your car: Rick0636 Mustang Audio & Video 31 07-03-2004 09:03 PM
My lil bro showing off my hot rims Black95GT The Bar 12 12-07-2003 12:46 AM
11:44 AM
