Code p0010 - Mustang Evolution
Old 08-15-2014, 05:10 PM   #1
cstyle408's Avatar
Code p0010
Need help please asap. I have this code. Rpms take forever to drop to normal
cstyle408 is offline   Reply With Quote
Old 08-15-2014, 05:37 PM   #2
cstyle408's Avatar
Mustang P0010 "A" Camshaft Position
Actuator Circuit.
Thats what the code reader tells me. Can someone explain how to fix this? Or post a diagram of where this sensor is located. Thank you in advance
Old 08-15-2014, 05:38 PM   #3
99_GRUMPY_GT's Avatar
Did you change your oil lately or add some kind of additive to your oil lately?
2015 Race Red Performance Package GT 5.0 (435hp) stock
Still in the making Updates coming soon!
99_GRUMPY_GT is offline   Reply With Quote
Old 08-15-2014, 06:00 PM   #4
cstyle408's Avatar
No. Where is this sensor located?
Old 08-15-2014, 07:04 PM   #5
Lol
Are we the only ones who are offering any help... us in the 96-04 forum I mean.
Cstyle408, you must have a 05 or later car right?
Old 08-15-2014, 08:07 PM   #6
cstyle408's Avatar
No. I have a 98 gt 5 speed. But its wierd cuz i just rescanned the car and that code is gone but now i have p0174.
Old 08-15-2014, 08:11 PM   #7
I thought that was strange because that code is for a component that our engines don't have.
P0174 huh?
Old 08-15-2014, 08:18 PM   #8
Anyway, good ole P0174....
My standard answer is to clean your Mass Air Flow sensor and to check the entire intake system for vacuum leaks. Also check the vacuum lines.
Old 08-15-2014, 10:55 PM   #9
cstyle408's Avatar
I just recently cleaned the throttle body, maybe i didnt tighten the hose clamps on the cai good enuff? I looked on a dtc website and it says posible vacuum leak in the hoses to the evap canister. What a coincidence that i just replaced the evap valve and purge flow sensor....
Old 08-16-2014, 04:32 AM   #10
well you answered your own question. Anytime you do work on your car and then throw a CEL just simply go back over your work and double check everything.. If new parts were installed, inspect and test. Its very possible you installed a defective part.
as said above though, clean your MAF and also check the voltage make sure its functioning properly. I researched the code and other then cleaning the MAF and checking for vacuum leaks another possibility is a dirty fuel filter, so check your fuel pressure as well.
TurboCobra is offline   Reply With Quote
Old 08-16-2014, 08:12 AM   #11
Originally Posted by straybullitt View Post
Lol
We just have too much time on our hands I guess!
Old 08-16-2014, 09:05 AM   #12
Mile high JDF's Avatar
Or you guys actually know what you're talking about. I for one can't diagnose CELs to save my life
- Silver 2007 Corvette
Current - DHG 2001 Bullitt
Old 08-17-2014, 06:59 PM   #13
WJL
FYI the cam sensor is on the Left Head behind the power steering filler at least that's where it is on a 98
WJL is offline   Reply With Quote
FORD MUSTANG BRAINIACS what does r-code and/or c-code mean? kele74 Classic Mustangs 4 03-16-2010 05:12 PM
CEL code P1131? candmforever Pre-2005 V6 Mustang 20 09-15-2009 10:47 PM
autozone won't pull my cel code!? candmforever Pre-2005 V6 Mustang 8 12-10-2003 09:19 PM
ECU code FA23...sound right? MUSTANGJUNKY420 Pre-2005 V6 Mustang 6 08-11-2003 04:35 PM
paint code for my car... dark Mustang Audio & Video 1 08-01-2003 03:14 PM
04:44 AM
