Leaking Steering Rack! - Mustang Evolution
Old 08-19-2014, 09:41 AM   #1
Michael.s.king's Avatar
Region: Maine
Thought it was my outter tie rod, mechanic said steering rack is leaking on both sides and is most likely the steering rack that needs to be replaced as it is making the tie rod loose in there.
Do I need to replace the steering rack? Can I just replace the bushings and that will help with the leaks? Any help would be awesome!
Michael.s.king is offline   Reply With Quote
Old 08-19-2014, 02:34 PM   #2
If the steering rack is leaking fluid it probably needs to be replaced.
Now would be the ideal time to also replace both of the inner and outer tie rods and the steering rack bushings.
Old 08-19-2014, 03:53 PM   #3
Region: Maine
Alright thanks, what do you recommend for bushings?
Anyone have a write-up on replacing/installing a steering rack?!?!
Old 08-19-2014, 04:17 PM   #4
I have a set of Pro-thane steering rack bushings for my autocross car and set of OEM style rubber bushings in my street car.
The steering rack is fairly easy to replace. There are just two bolts holding it on. You need to remove the two power steering lines and separate the outer tie rods from the spindles and it comes right off.
If you want to get a quality rebuilt steering rack, go to redheadsteeringgears.com.
Old 08-19-2014, 04:26 PM   #5
Oops.
Forgot to include unbolting the steering shaft from the steering rack.
Old 08-19-2014, 04:56 PM   #6
99_GRUMPY_GT's Avatar
Oops.
That would help!
2015 Race Red Performance Package GT 5.0 (435hp) stock
Still in the making Updates coming soon!
99_GRUMPY_GT is offline   Reply With Quote
Old 08-19-2014, 05:36 PM   #7
Sorry no write up that I know of But it's not that difficult. Can be done in a couple of hours.
Biggest pain for me was getting the little Teflon washers on the power steering lines. Supposedly there is a tool to help get them on but I just put them in some warm water to loosen them up and as gently as possible shimmied them on.
You'll lose maybe a quart (probably less) of fluid so have some to replace. My 2004 used ATF per shop manual.
Also you'll need to get an alignment afterwards
Old 08-19-2014, 05:59 PM   #8
Region: Maine
You guys are all life savers! Can I just clamp the power steering lines going into the rack and then drain the fluid that is in the rack? Or do I have to drain it all?
Old 08-19-2014, 06:15 PM   #9
When you purchase the steering rack, in the instructions, it may say to flush the old fluid out of the system. In any case, it's not a bad idea to get as much of the old fluid out and replace it with new.
Old 08-19-2014, 07:18 PM   #10
Region: Maine
Well I'm installing it in a bay I am renting and wanted to flush the fluid at home. But I assume I can just clamp it or something, thanks again
Old 08-19-2014, 08:41 PM   #11
The power steering lines are copper not flexible hose so you can't clamp them.
You really won't lose that much fluid.
I didn't flush my old fluid out just added new to what had drained out.
Once everything was connected back up I filled up the reservoir to the line. Cranked the engine and let it run for maybe a second or 2 then turned off again. Filled reservoir back up, stated ran it for another second or 2 and shut off. Checked reservoir, filled it. Then start car and let it run, turn the wheel all the way to the left and right periodically over 10-15 min to work all the air bubbles out, easiest to leave front end jacked up for that part.
Check fluid level again over the next couple of days, add if needed
Old 08-20-2014, 05:59 AM   #12
Region: Maine
Oh yeah I guess clamping would be kind of hard then haha! So when I disconnect the lines going into the rack, there isn't a lot of fluid that comes out?
That's pretty much the only part I'm worried about, the power steering fluid. But I guess I'll just get a bucket thing like they have for oil changes.
I heard aluminum bushings are the way to go, any thoughts on this?
Old 08-20-2014, 06:03 AM   #13
The last thing you want to do is add new to old fluid. Especially since the fluid in the rack and steering box has probably never been changed. It is wise to drain the system and replace with new.
Old 08-20-2014, 06:36 AM   #14
Region: Maine
What's the easiest way to flush all the fluid?
Sorry for all the dumb questions... Lol
Old 08-20-2014, 09:41 AM   #15
Aluminum are good! I can't use them because of class rules.
The easiest way to flush the system is to disconnect the return line from the pump and turn the engine on and let it pump itself out. You can add some fluid as you are doing it.
Old 08-20-2014, 11:07 AM   #16
Tiffsobelle's Avatar
Thought my steering rack needed to be replaced and had found this via google:
How To Replace a 1979-2004 Rack-and-Pinion - Mustang Monthly Magazine
Tiffsobelle is offline   Reply With Quote
Old 08-20-2014, 06:05 PM   #17
Region: Maine
Oh **** yeah! Thank you!
Old 08-21-2014, 07:32 AM   #18
Anytime! Hope you get it all fixed up
Steering Rack improvement(s)/ Vibration cure(s) jimbullit 2005-2010 Mustang GT 2 05-06-2009 11:43 AM
PLEASE SOMEBODY HELP!! (Steering Rack) savedbygrace 1979-1995 Mustang GT 6 10-11-2008 11:22 AM
Power steering rack Haohmaru 1979-1995 Mustang GT 2 05-12-2008 12:36 AM
Steering Rack bluemustang 1979-1995 Mustang GT 9 04-30-2007 08:26 AM
Maximum Motorsports steering rack bushings fastmustangs1 Pre-2005 V6 Mustang 1 10-22-2004 04:16 PM
04:29 PM
