Tips to help front suspension - Mustang Evolution
Old 08-20-2014, 03:54 PM   #1
Slow4V's Avatar
Alright Well Lately My Front End Has Been Feeling Unstable , AND Kind Of Like a Boat. .
Well to give you a idea of my suspension mods ..
Maximum Motorsports CC plates( haven't had chance to get alignment yet )
Tokico HP Struts AND shocks ( kind of thinking they are blown since my car is so low , that they wore out fast )
SVE full length subframe connectors welded in.
CHE upper spherical control arms
I did have lower control arms but bushings went bad so I'm back to stocks..
Cut springs ( car Is low )
Energy suspension sway end links
I did notice my sway bar bushings torn but not too sure if that would be a drastic change. .
My rack and pinion and power steering pump have been replaced too
Just hitting bumps are hard, a little bouncy not too bad, when I'm on hi highway it's a little loose ,
Any Suggestions Would Be Greatly Appreciated
Sent from my SM-G900T using Mustang Evolution mobile app
ID:	163931   Click image for larger version
Old 08-20-2014, 03:57 PM   #2
1st off ditch the cut springs and your shocks and struts, get non-cut springs and adjustable shocks and struts. Doing all of it you might as well just she'll out a bit more for coilovers.
Could probably use a new steering rack, I would look at MM's website for most of this stuff.
A new K member would help also, if you want something strong go with MM, but if you want max weight savings then UPR is find, just won't be as great around corners.
And get an alignment.
Old 08-20-2014, 04:54 PM   #3
99_GRUMPY_GT's Avatar
Well first off, the worst thing you did was cut your springs. Your springs are spring load rated, once you take a coil here and a coil there, the coil can no longer support the load requirements given, hence the bouncey ride. Now at highway speeds the spring can feel like it is floating which gives the characteristics of a car not gripping in the front but floating. Secondly, with cutting springs, it hammers the sway bar bushings and hence splitting, wears your control arm bushings and steering rack. Not to mention the balljoints and tierod ends.
As mentioned before, junk the springs for a perfectly good set of lowering springs and do not cut them. Caster and camber plates do no good if you do not get an alignment. I am not trying to be an *** with what I am writing, but, your ride looks nice by the sig pic, so why half-*** your suspension? Does not make sense. You are answering your own problem with what you wrote in the post.
2015 Race Red Performance Package GT 5.0 (435hp) stock
Still in the making Updates coming soon!
99_GRUMPY_GT is offline   Reply With Quote
Old 08-20-2014, 05:06 PM   #4
Mile high JDF's Avatar
I would at least get an alignment and and a bump steer kit to see how that affects anything before just throwing a bunch of parts at it
- Silver 2007 Corvette
Current - DHG 2001 Bullitt
Old 08-20-2014, 06:29 PM   #5
Slow4V's Avatar
So
1. New springs
2. New Struts
3. BumperSteer kit
4. Alignment
Old 08-20-2014, 06:52 PM   #6
Originally Posted by Slow4V View Post
So
1. New springs
2. New Struts
3. BumperSteer kit
4. Alignment
OK, here is what in my opinion needs to be done.
1) inspect your frontend, balljoints, tierods, rack, lower control arm bushings, and swaybar bushings, shocks and struts.
2) replace or repair what is bad.
3) after you replace the springs and do the above, get an alignment.
4) K-member and all the others can wait once you get the basics completed. Then once the basics are completed, you would then have a proper base line to work with.
You have to make the determination of what you want with handling characteristics after the base line has been established. But without the basics fixed, how do you know where to start. We all here on this forum can throw ideas at you of what would be nice and what we run to give advise on. But like I said, get the basics cleaned up, then you let us know what you want and we can go from there. You may find out once the basics have been repaired, it is what you were after in the first place, and you may not want to do nothing else. But then again, you may.
AJE Racing front suspension on 67 mustang CPRsm Classic Mustangs 16 08-10-2014 06:17 PM
Front suspension help Stanglover1966 Classic Mustangs 14 11-08-2012 06:26 AM
will trade fairings and lowered suspension for stock suspension vincent1 1996-2004 Mustang GT 2 06-22-2009 07:34 AM
Front Suspension Question 00vertstang Pre-2005 V6 Mustang 2 09-29-2006 10:55 AM
SLP Tips and stock tips from 98 Cobra SVT_Rob Mustang Parts for Sale and Wanted 7 08-10-2004 09:08 PM
04:18 PM
