Got BOOST? I dont! Help! - Mustang Evolution
Old 08-21-2014, 12:49 PM   #1
My car isn't getting up to boost, still seems to drive okay I notice a slight loss in power but I am missing roughly 3.5 psi of boost.
I checked everything seems to be tight and I really don't know where to start trouble shooting if anyone knows what I should be doing please post
TurboCobra is offline   Reply With Quote
Old 08-21-2014, 12:53 PM   #2
The supercharged/turbocharged car?
Old 08-21-2014, 12:56 PM   #3
No, Its a single turbo.
Old 08-21-2014, 01:00 PM   #4
I was driving fairly quickly around some farm roads, beating on the car for about a half hour and then I stopped building full boost. Stopped for an hour at a friends place and still the car wont build the boost
I checked all the pipes and connectors and everything is as tight as possible, I don't see any damage but I also have no idea what I am looking at hah Bought not built*
Old 08-21-2014, 01:12 PM   #5
It's either a leak in the system somewhere, a problem with the Blow Off Valve/wastegate, or, like my old turbo car, you toasted one of many turbochargers.
Did you check the intercooler for any damage or leaks?
Old 08-21-2014, 01:19 PM   #6
I checked every connection and every clamp is as tight as possible, I don't have a tool to check for leaks tho, is this something an auto parts store will carry or should I just spend money and get a better BOV? I kind of want one that is louder to be honest. How do I test the actual turbo itself? **** I wana cry lol
if its not one car its the other and when there both doing fine I am to broke to drive from fixing one. Living the dream
Old 08-21-2014, 01:23 PM   #7
V6 stang's Avatar
Pay to play that's why I'm not paying yet haha
Yes I edit my posts a lot, auto correct likes to sabotage me!
2012 Mustang GT Convertible
Roush Exhaust
2003 Mustang GT (Sold)
Old 08-21-2014, 01:43 PM   #8
Lol
I hear you! I'm spread a little thin myself... Living the Mustang dream.
A "low tech" way to check for leaks in the system is, find a tire inner tube (motorcycle) that you can cut on the opposite end of the fill valve, and then slip the two ends of the tube over the pipe from turbo to the intercooler and the pipe from the intercooler to the throttle body. Clamp the tube to two ends of the pipe so that the plumbing and intercooler are all sealed and then pump up the inner tube with about 10-15 psi of air and then spray everything with soapy water to see if any bubbles appear.
When the turbo spools up, does it make any abnormal noise?
Old 08-21-2014, 10:01 PM   #9
found the leak, one of the gaskets is missing. Looks like they used some cheap gasket maker and it crumbled along the one side. This has to be why I just need 2 get a gasket but not sure how great it is that crap gasket maker got sucked in im sure
Old 08-21-2014, 10:26 PM   #10
I'm glad that it was nothing serious.
There's a chance that gasket blew out rather than being ingested into your engine since the plumbing is under pressure (boost) at least part of the time.
« Hi | PI Swap done »
Got boost now i want juice! 2003mustangGT 1996-2004 Mustang GT 8 12-19-2012 03:05 PM
Boost line for boost gauge TooSlow4U 2011-2014 Mustang GT 0 07-20-2012 10:34 PM
Dont you hate when things dont go as planed 1995boss General Mustang Discussion 7 03-29-2012 02:34 PM
got boost?? SaturnMan8227 Pre-2005 V6 Mustang 8 02-25-2009 01:45 AM
Got a locking lug nut dont have the wrench/socket Ibanezplayer272 Mustang Wheels & Tires 19 12-30-2005 02:40 PM
11:16 PM
