i thought i had this figured out - Mustang Evolution
Old 08-21-2014, 04:50 PM   #1
zoneo's Avatar
okay guys, so ive been goign a little crazy with the plasti dip lately and i thought i figure it out but now im having second thoughts on that...
the first thing i dipped were my rims. it came out great, smooth finish.
then i did my hood. came out pretty smooth.
then i did my hood 2.0 and it was a MUCH larger surface before and it came out looking super rough, almost as if it rubs off with a light brush, and kind splotchy and you can kind of soo the gloss shine still
then i did the section between my exhaust tips and it came out looking REALLY smooth.
right after i did that i did my spoiler and its starting to come out just like my hood. except it definitely rubs off easily.
what am i doing wrong? am i not leaving enough time to dry, or do i just need a lot more coats? or maybe thicker coats? i dont make a lot of progress with each coat...
zoneo is offline   Reply With Quote
Old 08-21-2014, 04:53 PM   #2
crroy71's Avatar
Did you clean the surface good before applying? I clean with rubbing alcohol before I spray it.
Chris
crroy71 is offline   Reply With Quote
Old 08-21-2014, 04:58 PM   #3
zoneo's Avatar
yeah i usually use carwash soap and water but i just did water today. but both surfaces were cleaned the same with different results...
Old 08-21-2014, 05:03 PM   #4
99_GRUMPY_GT's Avatar
If you clay bar the already painted parts first and wash, then you should have no issues. The clay bar gets all the elelments and unseen grim or dirt that would intefer with cohesion.
2015 Race Red Performance Package GT 5.0 (435hp) stock
Still in the making Updates coming soon!
99_GRUMPY_GT is offline   Reply With Quote
Old 08-21-2014, 05:06 PM   #5
zoneo's Avatar
so thats why its so rough looking? it wasnt clean enough?
Old 08-21-2014, 05:12 PM   #6
zoneo's Avatar
This is a what I mean... This is my spoiler and you can See it go from smooth to... Furry..
Old 08-21-2014, 05:40 PM   #7
Tell you what, go and purchase a claybar kit. Use it as it is intended to be used, then spray your plasti-dip. And then tell me if it is different. I have seen the differrence for myself. Another thing you can look at is, is your tip clean on your spray can or gun? A dirty tip or clogged tip can cause an uneven like spray and give a rough/smooth spray.
Old 08-21-2014, 05:45 PM   #8
zoneo's Avatar
That's something I try to check regularly. Where's a good place to pick one up?
Old 08-21-2014, 05:51 PM   #9
Any auto store that sells car wash items or polish items has the claybar kits. They are cheap kits, I always have a claybar laying around for when I feel rough areas on my cars paint, then I use the claybar and good as new again.
Old 08-21-2014, 05:54 PM   #10
2 Stangz's Avatar
Region: Nevada
Yeah I wouldn't call that good prep work at all. Depending on the soap you may be okay but just wiping with water? C'mon
+1000 on the claying
Old 08-21-2014, 06:32 PM   #11
JHghers's Avatar
Walmart has meguiars clay bar kit for $20
No other man-made device since the shields and lances of ancient knights fulfills a man's ego like an automobile.
JHghers is offline   Reply With Quote
Old 08-21-2014, 08:04 PM   #12
The_Chech's Avatar
Lemme ask you this are you using the plasti dip cans until they are empty? I've found out that using the cans until there almost out of paint they like to sputter and kinda spit little tiny droplets every where and make it very rough finish and not smooth, sorta how yours looks from the pictures
Oxford White Roush Stage 1 SN# 6925--SOLD but never forgotten!
Kona Blue GT premium - Slammed on BC's and BMR's full rear suspension
The_Chech is offline   Reply With Quote
Old 08-21-2014, 09:18 PM   #13
JHghers's Avatar
I just did my wheels and yes I found that once they reached a certain level they tend to splatter more.
Old 08-21-2014, 10:36 PM   #14
racks2relax's Avatar
We did my boys and it came out really good. The texture wasn't super rough but not smooth. Everybody I know that's done it comes out like this. Done with the plasti dip rattle can.
Sent from my SM-N900P using Mustang Evolution mobile app
ID:	164041   Click image for larger version
racks2relax is offline   Reply With Quote
Old 08-21-2014, 10:47 PM   #15
GrabberBlue1993's Avatar
You're not cleaning properly before applying, and it looks like you are just spraying it on and not misting. Mist it all over, then wait a minute, then repeat. It will not be filled in there will be spots not dipped. Repeat this process about 10-20 times until everything is filled in, then do another coat or 2. You will have a perfectly smooth dipped surface, and it will look professional grade.
Source: Lots of experience plastidipping, people ask me if it's matte paint or wrapped all the time
"At least it isn't a Honda"
GrabberBlue1993 is offline   Reply With Quote
Old 08-21-2014, 11:19 PM   #16
Is it easier with the spray gun they sell?
Old 08-21-2014, 11:22 PM   #17
I would say yes, never used it though. All my plastidip work comes out professional-grade on my car with the rattle cans though
Old 08-22-2014, 03:27 AM   #18
Takes too long with the cans, ended up just laying the paint after the 3 coat. Misting it for the first 3 layers. Anyways the car ended up getting wrecked. :/
Old 08-22-2014, 09:11 AM   #19
V6 stang's Avatar
I had this happen on my old car.. I always thought it was just the wind or something. Cuz if I did it in a garage it came out perfect. Outside with the wind it came up rough and bubbly like that.
Yes I edit my posts a lot, auto correct likes to sabotage me!
2012 Mustang GT Convertible
Roush Exhaust
2003 Mustang GT (Sold)
Old 08-22-2014, 10:18 AM   #20
zoneo's Avatar
thanks for all the great tips guys! and as for the just using water part.. i had a hope, and it ended up bacck firing. ill keep you guys posted on my next endeavor with this. im gonna try to do it later today if my schedule allows it.
Old 08-22-2014, 10:33 AM   #21
PonyBoyV6's Avatar
Honestly, the way the dip looks, it looks like there either was an unsteady stream of product (tipped can) or a lack of aerosol in the can. Looks very sandpaper like. The reason i'm leaning towards tipped can and improper spraying technique, is based on what you said. Your vertical areas came out very smooth, but your horizontal areas came out blotchy and rough. While improper washing probably contributed, i'm not sure it would cause that rough looking result. It looks like the plasti-dip is clumping when it's tilted, and forming clumps or bubbles. As another poster said, use a light misting from about 6-10" away, and repeat until the entire area is covered lightly. Then apply more coats. Keep the can as upright as possible to avoid blotchy spraying.
PonyBoyV6 is offline   Reply With Quote
Old 08-22-2014, 10:44 AM   #22
zoneo's Avatar
i dont think its my technique only because everything you guys keep saying are all things im doing... 6-10", light even coats, no over spray, releasing when i change directions, all that.. i could maybe see the tipped can part, but how else and i supposed to do this? i took the spoiler off last time to paint it and put it on the floor
Old 08-22-2014, 12:34 PM   #23
PonyBoyV6's Avatar
It could very well be the tipped car, honestly. To do the spoiler, just hold it at a very slight angle, and mist over it while keeping the can as vertical as possible, and see if that helps. Keep in mind, this is by no means, Paint. Plasti-dip is its own beast, and it takes a bit of practice to get it to cooperate. Like I said, Give it a shot with the can less angled, try to keep the car in shade while doing it. And if that doesn't work, it could very well be paint prep as the culprit. I've had results very similar to yours, but that was from a combination of poor angled spraying, and too cold of conditions. Hope it works out for ya man
Thought I had it figured out 11stangGT Mustang Wheels & Tires 16 11-17-2013 12:36 AM
Finally figured out the deal with my car. Zim 1979-1995 Mustang GT 14 09-19-2005 08:49 AM
Figured out the Integra troublecode 232SCstang The Bar 6 07-12-2005 02:06 AM
Check out the pics now figured it out Matt'sredbeauty The Bar 19 01-19-2005 10:26 PM
Figured my setup out... Tbird232ci The Bar 1 12-11-2003 09:43 AM
04:35 PM
