400rwhp on a 00 gt - Mustang Evolution
Old 08-21-2014, 11:59 PM   #1
Tangtang2.0's Avatar
400rwhp on a 00 gt
Is it possible to reach 400rwhp in a 00 gt keeping it n/a?
Tangtang2.0 is offline   Reply With Quote
Old 08-22-2014, 12:25 AM   #2
It has been done, but you need a fully built motor with nice heads, higher compression and good cams all put together to work with each other. Not cheap and not easy.
Old 08-22-2014, 07:39 AM   #3
Got $10k to spend?
-5.0 stroker high compression forged shortblock
-TFS heads
-Max effort NA cams
-Kooks Longtubes
-Eddy Intake
That basic combo will yield 375-400rwhp on a 2V. Completely and TOTALLY not worth it when you can get better results with a supercharger on the stock motor and retain the stock street manners and gas mileage of a factory 2V.
If you are talking about with just bolt ons and cams, its an achievement to hit 300rwhp in that instance. Cammed 2Vs normally run in the 285-300rwhp range and do mid-low 12s at the 1/4 setup properly. There are some that break into the 11s but they are often NPI bottom end cars with a lot of weight reduction and a really good driver or an auto swap or both.
2000 Mustang GT Steeda #0048
Old 08-26-2014, 08:26 AM   #4
Got $10k to spend?
-TFS heads
-Max effort NA cams
-Kooks Longtubes
-Eddy Intake
Yes so that's what I thought that I was better of supercharging it.. I might need to do a engine rebuild first before I get knot all of that my car had 164k lol ...so how much do u think I'll be making if I put in 4.10s pulleys off road x long tubes tb and plenum and a good tune? Sorry for the late reply
Old 08-26-2014, 08:34 AM   #5
Don't be concerned about the HP numbers, do the mods and drive the **** out of the car.
TurboCobra is offline   Reply With Quote
Old 08-30-2014, 04:30 AM   #6
If you go with a supercharger I'd forget the 4.10s and go 3.55 or 3.73
400rwhp NA? JMoney 2011-2014 V6 Mustang 265 11-27-2013 08:25 AM
08:34 PM
