Steeda UDP's on sale :) LMR - Mustang Evolution
Old 08-25-2014, 02:29 PM   #1
just placed my order for some Steeda Under drive Pulleys! There currently on sale on LMR for only $191
Other then needing the harmonic balancer puller, is there any way I can screw this install up lol, I notice the pulley has markings on it, is there a way to screw up the timing or is it just as simple as bolting the new one on?
TurboCobra is offline   Reply With Quote
Old 08-25-2014, 03:03 PM   #2
99_GRUMPY_GT's Avatar
The harmonic balancer will have a key way that will line you up. You will need a harmonic balancer puller to get it off. You can rent one from AutoZone or just buy one.
2015 Race Red Performance Package GT 5.0 (435hp) stock
Still in the making Updates coming soon!
99_GRUMPY_GT is offline   Reply With Quote
Old 08-25-2014, 03:40 PM   #3
I just watched an install video of the Steeda UDP's and it says to put Black RTV on the key way slot or else the engine will leak oil. Is this actually necessary? Is this only with the steeda or does that go for an OE harmonic balancer as well?
Old 08-25-2014, 03:43 PM   #4
No it is not Steeda specific, it is true for stock balancer's.
Old 08-25-2014, 04:46 PM   #5
The_Chech's Avatar
Just put a line of RTV on the line you'll see it when you get the crank pulley. Make sure when you use the larger bolt in the kit to seat the crank pulley to not go to far as the bolt is a lot larger then the stock one and can cause some issues if bolted in to far. Seat the crank pulley just enough that the stock bolt can catch some threads and bolt it in the rest of the way with the stock one. There is also a specific way to torque the crank pulley as well so check the instructions for that one. I believe it was torqued to 65 ft lbs then one full rotation counter clock wise to loosen then torqued to 36 ft lbs.
Oxford White Roush Stage 1 SN# 6925--SOLD but never forgotten!
Kona Blue GT premium - Slammed on BC's and BMR's full rear suspension
The_Chech is offline   Reply With Quote
Wanted: Steeda UDP's Jrh2592 Mustang Parts for Sale and Wanted 2 09-05-2014 07:47 PM
Steeda UDP BadAssStang07 2005-2010 Mustang GT 16 01-22-2014 10:50 PM
For Sale: 4.6l Steeda udp 2002VertGT Mustang Parts for Sale and Wanted 15 12-08-2013 10:02 PM
Ordered an ASP UDP from LMR! Just_John Pre-2005 V6 Mustang 25 05-06-2012 01:12 AM
Group Purchase: ASP UDP & Steeda Tri Ax via www.crossroadzdirect.com!!! Autobadges.com Mustang Parts for Sale and Wanted 3 05-11-2004 06:58 PM
09:37 AM
