Double-Din Install - Mustang Evolution
Old 08-25-2014, 10:39 PM   #1
Double-Din Install
I have a double-din head unit from my old car that I would like to put in my 98 mustang. I've seen that other people have done it and I want to because I love my stereo. My friend has an 04 mustang I think with the same shaped stereo dash panel but his has a double din space and mine has 2 single din spaces (cassette and cd). Does anyone know if I could possibly swap my stereo dash panel for a newer models? would it mount properly? Or would I have to cut out sections of my own dash panel for it to work?
oceansniffer is offline   Reply With Quote
Old 08-26-2014, 12:11 AM   #2
There interchangeable . Go to a scrap yard auto recycler junk yard find one with the double din slot and from there its an easy swap out.
TurboCobra is offline   Reply With Quote
Old 08-26-2014, 08:00 AM   #3
99_GRUMPY_GT's Avatar
Or the double dins are on E-Bay all the time in different interior colors, tan and black, or charcoal.
2015 Race Red Performance Package GT 5.0 (435hp) stock
Still in the making Updates coming soon!
99_GRUMPY_GT is offline   Reply With Quote
Old 08-26-2014, 08:52 AM   #4
Not quite a direct snap in...
Double Din Radio Bezel Install
The biggest thing is you need to figure a way to support the bottom radio bolts because on the 01-04 dashes there are bolts for it behind the bezel. You can see in the linked thread this guy just ran screws through it. I've seen some ppl run pop rivets too and that looks better but most ppl figure out some sort of DIY bracing out of hardware store metal stock and hide it.
Then you need to run block offs in the switches for that 01-04 bezel since you won't be using them for anything unless you want to re-wire the fog/defrost in there and find some working switches out of the JY.
The block offs are here
http://www.latemodelrestoration.com/...ol-Delete-Plug
Or... if you have some fiberglass skills, you can just do this
double din using 94-98 radio bezel start to finish
The custom one looks much nicer IMO but the 01-04 is much easier if you can find one used that is in good shape. You can get them for $130 new as well but they will have to be painted to match a 94-98 car. 99/00 will color match just fine.
2000 Mustang GT Steeda #0048
Old 08-26-2014, 02:25 PM   #5
Thanks! The custom job actually looks kind of doable and I still have plenty of filler from my last car haha. Once I get my top priorities fixed I will be installing this. I'll be sure to post pics too
Old 08-27-2014, 08:02 AM   #6
Yeah the custom job is the best and it puts the radio up as high as possible which is optimal in these cars. The OEM one is too low IMO but it does make the swap a nearly direct bolt in. Like I said just have to go buy a piece of metal stock from home depot, cut a few pieces, measure/drill some holes and mount them.
I think once MirrorLink becomes commonplace on all double DINs and supported by all phones that is going to be the way to go. Throw the phone on the charger in the armrest and control everything from the headunit. I may look into that myself, my G2 supports MirrorLink.
Changing single din to double din Mfore33 Mustang Audio & Video 0 08-18-2014 10:24 AM
Double Din/ Half Din Justasix98 Mustang Audio & Video 1 02-20-2012 02:25 AM
ebay double din 03GT88 Mustang Audio & Video 11 09-22-2011 12:57 PM
Aftermarket Head Unit, Single or Double DIN? Tib Mustang Audio & Video 15 05-28-2011 12:24 PM
Eclipse CD3100 + wiring harness & double din adapter jimmy_beaner Mustang Parts for Sale and Wanted 2 04-07-2008 07:56 PM
03:09 PM
