Nitrous - Mustang Evolution
Old 08-27-2014, 07:32 PM   #1
jonathanadams22's Avatar
Nitrous
So I went to test my nitrous today and it seems like it's not activating. It doesn't feel any different at all. The window switch is all hooked up but not programmed for a set rpm. Will this cause the nitrous to not activate?
jonathanadams22 is offline   Reply With Quote
Old 08-28-2014, 12:17 PM   #2
Ish and Rapinator are our two resident nitrous experts.
They should be able to get you squared away... If they see this thread.
Old 08-28-2014, 12:27 PM   #3
Rapinator126's Avatar
Are you positive the window switch is not set?
you have a full throttle switch also right?
1. is this your first time testing it out? If so, you never test it out on the street for the first time. You do it while still in your garage/ drive way, this is how
Take the Intake tube off. Have someone watch the nozzle/ plate, turn key on ( not the car ) and hit it. Should see nitrous and fuel spraying out.
2. This does not work, check all your fuses/ main wiring harness.
Rapinator126 is online now   Reply With Quote
Old 08-28-2014, 12:34 PM   #4
Also how did you hook up your window switch?
Old 08-28-2014, 06:31 PM   #5
Nitrous
I did not hook the system up and I am positive it's not programmed. I had the guy who installed it test it and said it was working wether or not he tested it in the garage or on a street I don't know, but when I tested it it doesn't seem to do much at all. It's a 100 shot. With the big tires I have on it I would think it would at least spin the tires (22") getting changed soon, and also my traction control doesn't work so I definitely thought it would spin them. I hope that I just don't have unreal expectations for a 100 shot. I just thought it would put me back in my seat some.
Old 08-28-2014, 07:20 PM   #6
What gear were you in when you hit it?
You will feel a 100 shot.
Old 08-28-2014, 08:02 PM   #7
2nd I also checked and the wot switch was poorly installed so I don't know if it was activating that either
Old 08-28-2014, 08:05 PM   #8
That's your problem more than likely. Fix that first.
I could sit here all night and and give you reasons etc, let's start at square one. Fix that
Old 08-28-2014, 08:06 PM   #9
Screaming Mach's Avatar
Did you open the valve on the bottle?
Screaming Mach is offline   Reply With Quote
Old 08-28-2014, 08:09 PM   #10
Lmfao. Ha hahahha if not then lord help us
Old 08-28-2014, 08:19 PM   #11
Lol of course u would have to be an idiot to not open the valve. Haha
Old 08-28-2014, 08:24 PM   #12
Get the wiring cleaned up like Rap said.
I wonder, if you are not using a bottle heater, if maybe you aren't getting a full "hit"?
Old 08-28-2014, 08:43 PM   #13
Going to test it now tried fixing the wot switch and I programmed the rpm window switch.
Old 08-28-2014, 09:11 PM   #14
I have everything for it including bottle heater the idiot who installed doesn't have it hooked up right. I'm taking it to an actual custom shop to look it over and fix the problem thanks for the help guys.
nitrous
Running a bigger shot of nitrous / NITROUS GUYS Jsmorley81 2011-2014 Mustang GT 5 02-14-2014 01:31 PM
Nitrous Express wet nitrous kit Zim Mustang Parts for Sale and Wanted 24 06-15-2005 12:43 PM
getting nitrous MusclesFromBrussels Pre-2005 V6 Mustang 11 08-06-2003 02:43 PM
SC and Nitrous ERICK Pre-2005 V6 Mustang 11 07-21-2003 08:28 PM
Supercharger or Nitrous? ERICK Pre-2005 V6 Mustang 8 05-12-2003 02:41 PM
06:34 AM
