Flashing check engine light after hard pull - Mustang Evolution
Old 08-28-2014, 02:42 PM   #1
Pancakes's Avatar
Anyone ever had this issue. Did a hard pull up to 4th just for fun, when I started slowing down the engine light started flashing for a minute then went away. Haven't seen it since.
If I had to make a guess, its that the plugs got soaked in unburnt fuel from pushing down on the pedal and it didn't ignite it all. Engine light went away after the fuel burned off. But that's a wild guess. I'm not too concerned. Any inputs though?
Pancakes is offline   Reply With Quote
Old 08-28-2014, 03:08 PM   #2
You're close.
The flashing CEL is often a misfire that is detected.
If you scan for trouble codes, there should be a "pending" code that will tell you what happened.
Old 08-28-2014, 06:52 PM   #3
escottcarp's Avatar
I've had the same situation in my wife's minivan. I wasn't concerned at the time either. But, I had a problem with a misfire in that same cylinder a few months later.
Have a big Mustang day!
escottcarp is offline   Reply With Quote
check engine
2013 gt flashing engine light 2013fiveO 2011-2014 Mustang GT 25 04-14-2016 03:37 PM
Flashing overdrive light after jmod FriedChicken Pre-2005 V6 Mustang 8 07-16-2013 08:41 PM
2013 V6 Check Engine Light Flashing vcantrell 2011-2014 V6 Mustang 8 06-22-2013 09:43 PM
Check engine light flashing!!! rich671 Pre-2005 V6 Mustang 8 09-14-2012 05:39 PM
Flashing Service Engine light. Vile87 Pre-2005 V6 Mustang 9 08-29-2012 12:45 PM
07:41 AM
