Charging Problems - Mustang Evolution
Old 08-28-2014, 07:31 PM   #1
mattski's Avatar
Charging Problems
For the last two days I've been trying to figure out why my battery keeps draining at idle and while driving. Took out the alternator and had it tested and it was good. So I figured maybe the battery? Took it and had it tested and it was also good. Checked all the connections and they were all tight. I've read about a fuseable link somewhere in the harness that I have yet to look for.
Trying to figure this out before I go crazy! Electrical is not my forté.
Sent from my LG-D800 using Mustang Evolution mobile app
mattski is offline   Reply With Quote
Old 08-29-2014, 07:42 AM   #2
rollo1987's Avatar
Electrical sucks. Now did you check the wiring just because the connections are tight dosnt mean that wire is good. U had an issue just the other day on a hummer not charging. Battery was good Alternator pushing out right voltage. It came out to be a wire they burned out. Repaired wire it was good. Also check your belts. If they are slipping the alternator won't push out enough volts to charge the battery. Those are what I would check. I know for sure others have differnt things. Good luck man.
rollo1987 is offline   Reply With Quote
Old 08-29-2014, 07:59 AM   #3
rollo1987's Avatar
Old 08-29-2014, 10:01 AM   #4
mattski's Avatar
Belts tight. Continuity through the wires seems good. Just can't seem to find the fusible link. Anyone got a picture of their alternator wiring and how it's run? Because when I pulled the motor to rebuild it I didn't really take any mental notes on the wire placement
Old 08-29-2014, 10:24 AM   #5
rollo1987's Avatar
I would send u one but my car is in the shop right not. Sorry
Old 08-29-2014, 10:27 AM   #6
rollo1987's Avatar
Another thing. Just because the belts are tight dosnt mean they are good. I had to change belts before. They were tight. But under the belts were.l very shinny telling me they were slipping. Causing the alternator not to charge. Let's hope it's something simple. It sucks you do all the work and found out some easy and cheap or free could fix it lol.
Charging System Problems 2 Stangz 2005-2010 Mustang GT 3 02-04-2014 09:55 PM
Apple stores to begin charging admission: MarkuzLS1 The Bar 11 07-28-2007 01:32 AM
charging system woes Thomas91169 Mustang Audio & Video 15 08-12-2006 12:34 AM
PLEASE Help!! charging issues...91 GT scorpionSStang 1979-1995 Mustang GT 11 02-10-2006 04:56 PM
battery charging problem I_luv_HP&trq Pre-2005 V6 Mustang 20 09-24-2005 02:58 AM
07:59 AM
