99-04 mach 1000 audio - Mustang Evolution
Old 08-29-2014, 07:53 AM   #1
Nate98stang's Avatar
Ok, so I just bought my 03 sonic blue gt yesterday. It has the Mach 1000 audio package, is there a way to still use it if I change my head unit?
sent from galacy s5.
2003 Sonic Blue gt
ID:	164658   Click image for larger version
2002 5 speed Comp Orange Mustang GT. K&N CAI,JBA headers,BBK xpipe,SLP mufflers to turn downs,Exedy stage 2 clutch,MGW short throw,drilled and and slotted roters,front:17x9 black 10th anniversary cobras Rear:17x10.5 black 10th anniversary cobras,Roush stage 3 body kit,smoked tails and side markers.
Nate98stang is offline   Reply With Quote
Old 08-29-2014, 08:04 AM   #2
I have the Mach 1000 as well. Are you having problems with the stock head unit? I have the stock head unit still because I had another mustang with an aftermarket one and it looked so out of place.
Evan02 is offline   Reply With Quote
Old 08-29-2014, 08:51 AM   #3
It won't play burnt cds but other wise works fine, I just wanted to go with a double din touch screen
2003 Sonic Blue gt
Old 08-29-2014, 09:38 AM   #4
V6 stang's Avatar
Yes.. Especially if you pay someone to put it in, they should have zero problems. The biggest problem I've found is finding replacement speakers when u blow the ****ty stock ones. Ohm-age seems to be the issue. Mine are blow and sound like crap... But what's the point in replacing crap with crap. I even researched it but couldn't find much.
Yes I edit my posts a lot, auto correct likes to sabotage me!
2012 Mustang GT Convertible
Roush Exhaust
2003 Mustang GT (Sold)
Old 08-29-2014, 09:40 AM   #5
04beautyGT's Avatar
Putting in an aftermarket head unit should be easy...as long as you get the right wiring harness. I only have the mach 460 (it was pretty easy to find), but look around for a harness that is specifically for the mach 1000. I would try to ask a local audio place first and then Crutchfield.com. I think this is the one, but I would just take it out real quick to look at the wires and make an initial judgement.
04beautyGT is offline   Reply With Quote
Old 08-29-2014, 09:45 AM   #6
JWorm's Avatar
They sell a special wiring harness at best buy. Buy that and you won't have any problems.
JWorm is offline   Reply With Quote
Old 08-29-2014, 10:31 AM   #7
XSlashDashX's Avatar
Yes, you can change the head unit out and still have the mach 1000 working.
Old 08-29-2014, 10:45 AM   #8
Thanks guys!
2003 Sonic Blue gt
Old 08-29-2014, 08:28 PM   #9
Steve96's Avatar
Nice car!
1996 GT
Old 08-29-2014, 08:32 PM   #10
Nice car!
Thanks man
2003 Sonic Blue gt
Old 08-29-2014, 10:17 PM   #11
Peterzinyou's Avatar
Go with Crutchfield. They provide you with wiring harness for free, instructions, and free lifetime support.
Sent from my SM-N900T using Mustang Evolution mobile app
Borla S-Type stingers, BAMA SCT tuner, K & N Typhoon CAI, Classic Design Concepts light bar, MACH 1 chin spoiler, MACH 1000 w JVC Kvw 500 HU, plastidipped hood scoop, wing & Premium GT rims, painted calipers, 3.73 gears, black Bullitt fuel door, MMD hood struts, sub-frame connectors, SVE uca & lca, Power Stop drilled/slotted rotors
Peterzinyou is offline   Reply With Quote
Old 08-30-2014, 11:03 AM   #12
This.
Also, who the hell still uses burnt CDs? Lol, get something with a front usb port and throw in a $25 thumb drive with a 64 gig capacity and roll.
Old 08-30-2014, 11:25 AM   #13
This.
Only because it's a stock radio I never buy cds I want a touch screen double din
2003 Sonic Blue gt
Old 08-30-2014, 11:27 AM   #14
Just put in a good double DIN unit then, get one with a front or rear USB port. You can just put a thumb drive in the front or if its a rear port then run a usb extension cable from the rear into the glove box or console or whatever. IMO, rear usb is way cleaner but the front facing ones aren't too bad. Just don't want one sticking out where you'll bang into it going into 3rd.
Old 08-30-2014, 11:03 PM   #15
Been there and done that... Bottom line you need the correct harness and I would suggest getting it from Crutchfield. This will however not solve all your problems. Even though this will allow an aftermarket head unit to work with the Mach 1000 system the sound quality will be marginal at best IMHO.. The problem is, the MACH system is designed to work with a MACH head unit and nothing else. Each output of that head unit is customized to the amps it is feeding and the amps are customized to the speakers they are feeding. What you will discover is that if you leave your head unit flat, it will sound like crap. You need to play with the EQ, the high/low pass filters (selecting tweeters, woofers etc) in order to make it sound reasonable. And even then it's not going to sound great. I speak from experience after replacing my head unit with a top of the line Kenwood and could never dial the sound in correctly. I finally gave up and re-installed the Mach 100 head unit, bought an iPod adapter (USA-SPEC) and got my quality sound back.
If you look in the hardcore audio groups you will discover that people looking to improve on the MACH 1000 sound usually rip the entire thing out and start from scratch.
The MACH 1000 system is really a decent sounding system. Unfortunately it's behind the times (no USB inputs etc) and it's designed to work well with itself and is very hostile toward adding aftermarket parts. Especially speakers because the impedance of the MACH speakers is a non-standard value etc....
Can it be made to work as is with aftermarket components?
Sure, but you may not like the results.
Just my opinion.
vert03 is offline   Reply With Quote
Old 08-31-2014, 12:19 AM   #16
Just my opinion.
what ipod adapter?
2003 Sonic Blue gt
Old 08-31-2014, 08:27 AM   #17
This one:
USA SPEC iPodĀ® Interface for Ford Connects your iPod to select Ford factory radios at Crutchfield.com
However I would NOT recommend it because it's quirky. Sometimes it won't recognize the iPod Classic 160gb I have hooked up. I then have to power off/on the head unit.
I use it as a basic "shuffle and play all songs" unit and it works great like that.
If you are into custom playlists, displaying tags on the head unit etc then forget this one.
One thing though, it's the only unit I have found that uses the digital signal from the iPod.
It uses the connector on the bottom of the iPod so you are getting the best possible, in theory, sound quality.
The sound quality is excellent and you can use the EQ and other controls on the iPod to adjust the sound as well.
There are also inputs on the unit so you can use an AUX cable as well if you want.
Mine is an older unit so they have probably updated the firmware by now because a lot more phones/devices are supported compared to when I bought this a few years ago.
I also didn't pay $129.00 but something like $79 at the time so it was a better deal.
Make sure you plug your car into Crutchfield's site and make certain it's match and will work.
Old 08-31-2014, 01:13 PM   #18
Just my opinion.
I think I may save this or even sticky it at the top of the audio forum. Very good info and totally true. One of the best features of my 95 Cobra and now my 98GT is that they are NON Mach cars. If I had a car with a Mach unit in it I'd rip everything out or leave it in and figure out a way to run an aux input into it.
As for the current cars, when I start looking for a Coyote I bet I'm going to have a hell of a time finding a Premium or PP car without the Shaker in it. Maybe not.
Old 08-31-2014, 02:31 PM   #19
V6 stang's Avatar
You will prolly have a hell of a time. Seems shaker sort of just comes with premium. Every premium v6 I looked at had shaker. But that's the good part it's better than the old crap that blows. Having a 8" sub in the bottom is sweet (I believe that's what it has?)
Roush Exhaust
Old 08-31-2014, 04:45 PM   #20
Eh, if it has SYNC and bluetooth I can link it to slacker radio or whatever and stream. I'll be happy with that. Would have to research on how to retrofit better speakers/amps in and if the stock wiring is ok in the shaker unlike how it is in the mach.
Old 08-31-2014, 04:50 PM   #21
V6 stang's Avatar
Yeah I thought it was badass compared to the old Mach system. Sounded good an loud. The sync and bluetooth were very nice along with bein a nice touch. That's why I say I hate our interiors. Drove a 11 and hooked my phone up to it.. Got a taste of "luxury" at least compared to what I have lol
Roush Exhaust
Old 08-31-2014, 05:23 PM   #22
I don't know about the Mach 1000 but i swapped an aftermarket touch screen unit into my Mach 460 system. I believe the piece that is essential is a 12v to 9v converter.
Old 08-31-2014, 06:39 PM   #23
Lot's of great information on the Mach 460/1000 for 1999-2004 can be found here. The site this was originally posted on is long dead, but you can find it on Wayback Machine. No guarantees that all the hot links will also work though.
Mach 460 Information
Old 08-31-2014, 07:53 PM   #24
JWorm's Avatar
I have the 460. Bought the harness with the voltage converter for the amps. Installed pioneer touch screen. And the sound quality is much better. Exceptional highs. Amps work petfect. No distortion.
Old 09-01-2014, 06:46 AM   #25
fwalck's Avatar
I have the 460 in my car and I had all the harnesses needed and when I plugged it in my amps wouldn't turn on and the tweeters were the only thing working then I found out that depending on your head unit you may need to run the amp power wire to the main radio power wire because for some reason the head unit would not turn them on.
fwalck is offline   Reply With Quote
Old 09-01-2014, 09:35 AM   #26
The reason for the voltage regulator is that the Mach 1000 amps use a non-standard 5Vdc for the amp turn on lead where aftermarket head units use 12Vdc to turn on the amps. The voltage regulator drops the voltage from 12Vdc to 5Vdc so you don't get a pop when you power the head unit on. The Mach460 is actually a different animal than the Mach1000 and thus installing an aftermarket head unit works much better in those cars.
Here is a nice Mustang Sound Community on Google.
https://plus.google.com/u/0/communit...27569689411693
Old 12-03-2014, 03:39 PM   #27
I've got a stock 460 with no bass issues , crackled and poped a couple times and now nothing ,
Looked at every fuse in both fuse blocks , under dash and under hood
All look ok , got some amps from salvage and anouther radio from salvage and still no bass help !!
Love my 2004 pony but I want the stereo to work again .
john sloan is offline   Reply With Quote
Old 12-03-2014, 03:40 PM   #28
I forgot it has radio but no bass
Old 12-03-2014, 05:06 PM   #29
Because you know its all about that bass no treble...
Sent from my VS980 4G using Mustang Evolution mobile app
Old 06-29-2017, 01:05 PM   #30
jkeaton's Avatar
Just my opinion.
Old thread bump.....
Just wanted to add, I went ahead and tried to upgrade my head unit. Ordered a nice JVC double din and all the correct harnesses from crutchfield. What vert03 stated is exactly is exactly correct. I spent forever trying to get the eq's "dialed in" and it just never would sound as good as the factory head unit. The mach 1000 head unit has a "mach 1000" button that (I believe) turns on the trunk subs when pressed. Otherwise they are off. With the aftermarket head unit, ALL speakers were getting the same low frequencies as the subs. Turning the low frequencies down up or down affected all speakers, not just the trunk subs. Setting it to get the subs to hit would distort the other speakers. At any rate, I sent it all back for a refund and bought a Bluetooth FM transmitter and will just live with that.
03 GT Convertible, 5-speed
07 V6 Coupe
jkeaton is offline   Reply With Quote
Old 07-06-2017, 10:38 AM   #31
Lorraine's driver
ab_mach1's Avatar
Good info! Is that different then for the Mach 460 output?
Instagram: @ab_mach1
Old 07-06-2017, 11:44 AM   #32
Revvv's Avatar
I am using the factory Mach 460 amps and wiring with a Kenwood head. My stereo sounds fine. It could use a full update, but it works as it should.
Old 07-06-2017, 11:54 AM   #33
jkeaton's Avatar
Yeah, it would probably be OK for the 460 as there are not 4 extra amps and 2 subs in the trunk.
07 V6 Coupe
Mach 1000 Audio system zoneo 1996-2004 Mustang GT 23 12-15-2013 03:59 PM
Mach 460 with Mach 1000 Subs XSlashDashX Mustang Audio & Video 2 05-31-2013 12:07 PM
Mach 1000 Audio question XSlashDashX Mustang Audio & Video 2 04-01-2013 08:52 AM
mach 1000 audio Jeffsblack04 Mustang Audio & Video 9 06-23-2005 04:19 PM
Anyone have the mach 1000? Jeffsblack04 The Bar 5 06-22-2005 07:26 PM
04:18 AM
