Ignition cylinder - Mustang Evolution
Old 09-01-2014, 01:15 PM   #1
Lorenzod02gt's Avatar
Ignition cylinder
My key has gotten more difficult to turn in the ignition. What could be the problem?
Lorenzod02gt is offline   Reply With Quote
Old 09-01-2014, 03:06 PM   #2
99_GRUMPY_GT's Avatar
Age, Clean and lubricate the lock cylinder. Spray a liberal amount of electrical contact cleaner to flush away dirt and grime, followed by a quick spray of silicone or a drop or two of liquid graphite to lubricate. You can get the electrical contact spray from most Radio Shacks or auto stores, and also the liquid graphite.
2015 Race Red Performance Package GT 5.0 (435hp) stock
Still in the making Updates coming soon!
99_GRUMPY_GT is offline   Reply With Quote
Old 09-01-2014, 03:36 PM   #3
Yep. You can get Ford lock cylinder lubricant from the dealer as well. Do not use WD40.
vert03 is offline   Reply With Quote
Old 09-01-2014, 03:42 PM   #4
Tried pullin out the cylinder and spraying lubricant in there, It still Binds when turning it
Old 09-01-2014, 03:54 PM   #5
That probably means the cuts on the key are worn and not allowing the tumblers in the lock cylinder to fully retract when you put the key in.
They retract far enough for you to "force" the lock but at some point you won't even be able to do that.
Do all keys behave that way?
Is the door and trunk hard to open as well?
Of course the cylinder can be defective as well.
Old 09-01-2014, 03:57 PM   #6
It almost sounds like a rubber sound when turning the key
Misfire cylinder 7 & ignition coil Problem BeasGT 1996-2004 Mustang GT 1 04-03-2013 01:00 PM
Ignition lock cylinder Babydoll General Mustang Discussion 5 01-05-2009 04:51 AM
NOS ignition controllers TheSarge Pre-2005 V6 Mustang 3 09-16-2003 09:19 PM
Better ignition for 98.... TheSarge Pre-2005 V6 Mustang 2 09-15-2003 09:43 PM
11:46 AM
