2001 gt running hot - Mustang Evolution
Old 09-06-2014, 07:13 PM   #1
zli94's Avatar
Region: Oregon
2001 gt running hot
My mustang at an idle will get really hot. I'll let it idle for like 15 mins with the A/C on and it'll get really hot, almost to the red. The electric fan works and I changed the coolant. Then I'll drive it and it'll stay hot for another 15-20 mins then it'll slowly drop a little.
What could it be?
zli94 is offline   Reply With Quote
Old 09-06-2014, 07:19 PM   #2
2001 gt running hot
Probably thermostat
Old 09-06-2014, 09:39 PM   #3
99_GRUMPY_GT's Avatar
Probably thermostat
+2, probably the thermostat is sticking at closed position and eventually starts to open gradually. But most likely not completely. I would try replacing the thermostat. Cheap fix.
2015 Race Red Performance Package GT 5.0 (435hp) stock
Still in the making Updates coming soon!
99_GRUMPY_GT is offline   Reply With Quote
Old 09-07-2014, 01:17 AM   #4
+3
And after you've topped off the cooling system with a proper 50/50 mix of Anti-Freeze and DISTILLED WATER, you should "burp" the system by squeezing the upper radiator hose and progressively working the air pocket out towards the radiator... with the cap removed. You'll see the air bubbles exit out of the coolant tank.
Good luck!
Old 09-07-2014, 10:19 AM   #5
rocknbronco's Avatar
I'm going to say thermostat as well but it could also be a water pump or head gasket issue. Keep an eye on the coolant level and check the oil as well, also being into the off road scene I say check to see if anything is blocking the radiator fins, dirt, trash, dead animals, ect.
Mustang wanted for here...
rocknbronco is offline   Reply With Quote
Old 09-07-2014, 10:22 AM   #6
dead animals lol.
TurboCobra is offline   Reply With Quote
Old 09-07-2014, 10:34 AM   #7
Originally Posted by TurboCobra View Post
dead animals lol.
Seriously I worked for a large quick lube chain I was amazed at the number of dead birds, bats, ect stuck to radiator's or in air intake boxes.
Hot hot! OutlawGT 2.3 Mustang 7 12-04-2011 10:39 PM
running hot 04TRV6 Pre-2005 V6 Mustang 13 06-22-2011 06:33 AM
Running Hot Gray Ghost 1979-1995 Mustang GT 13 01-14-2011 12:02 AM
91 Mustang GT 306 Running Pretty Hot! 91StangGT5.0 1979-1995 Mustang GT 8 10-22-2009 08:01 PM
Running Hot.... Shortie630 Pre-2005 V6 Mustang 12 03-25-2004 10:19 PM
02:40 PM
