2004 v6 frozen turn signal - Mustang Evolution
Old 09-07-2014, 10:50 AM   #1
Hi guys, my turn signal will flash for a few seconds but then freeze in the on position. What would you recommend I do to fix it?
Thanks,
Arlene
aapura is offline   Reply With Quote
Old 09-07-2014, 11:20 AM   #2
You either have a bulb that is burnt out or the turn signal."flasher" has failed.
Do a quick check to make sure all of the bulbs are working and if they are all good, go get a new turn signal flasher for your car.
Old 09-07-2014, 11:22 AM   #3
99_GRUMPY_GT's Avatar
Does the hazards work? And do you hear the flashers blinking from the dash? If the hazards work, then I would tend to think that the EFM (Electronic Flasher Module)is going bad. It is located left side of the stereo behind the center console and under the steering column. If it is original, never replaced, it should be yellow, and square 1" by 1" relay module. If a plug and play relay, costs about 5 bucks at a local auto parts store. If that is working and not bad, then the only other area of concern would be the multi-function switch which is the turn signal lever that attaches tot he steering column and has 3 plugs going into it.
But check the EFM first.
2015 Race Red Performance Package GT 5.0 (435hp) stock
Still in the making Updates coming soon!
99_GRUMPY_GT is offline   Reply With Quote
Old 09-07-2014, 11:24 AM   #4
If a bulb is out, be it front or back, the one not blown and the dash indicator would just flash rapidly.
Old 09-08-2014, 03:04 PM   #5
The OP sent me a thank you message to let me know that the EFM was the problem and she got one from the auto store and installed it and now the turn signals work as they should now. I asked her to do the close out, this morning, but just in case she does not have a reason to log on to this site for awhile like alot of the one timers do, I am doing it for her. Just in case someone else has this problem and wants to know what the fix is.
Old 09-08-2014, 07:37 PM   #6
hey, how do i close out the thread? thanks again!
Old 09-08-2014, 07:40 PM   #7
You just did...
Old 09-08-2014, 07:41 PM   #8
Haha thanks straybullitt and grumpygt
96/04 combo turn signal switch Cobra GT Mustang Parts for Sale and Wanted 1 04-17-2009 08:53 AM
frozen turn signal ceilingguy Pre-2005 V6 Mustang 2 04-10-2009 01:34 AM
turn signal prob gearbanger67 Classic Mustangs 2 10-09-2007 08:37 PM
Sequental Turn signal Discount till the 9th!!! Rellik Mustang Audio & Video 2 11-10-2003 11:04 AM
12:13 AM
